Eagle netburner library
thomastaranowski
Post by thomastaranowski »
Does anyone know if there is a netburner component library for the Eagle layout tool?
Re: Eagle netburner library
Hi tom: I remembered these two files from the old Yahoo NB group and zipped them for you. I have no idea if they are OK. I also seem to remember seeing some NB eagle footprints on sparkfun a while ago, but maybe not...?
5282_NBLibs.zip
(8.12 KiB) Downloaded 739 times
v8dave
Post by v8dave »
Hi all,
Do disrespect to the person who created them, but I would be careful about using someone elses library files. I used to do that a few years ago with Altium Designer and got stung with one of the built in libraries with a wrong foot print. I now use only my own library parts I have either created or copied and fully verified before I use any others.
Once you know how to create library parts, and I would suggest you make this a priority as it greatly adds to the software use, then you will find it quite quick to make all you own parts.
i concur... i don't use eagle now, but the symbols and footprints are really easy to build.
Chris Ruff
Post by Chris Ruff »
I am an Eagle user and I have designed a bunch of boards with it. I agree that using your own footprints is the way to go. I personally prefer two connectors (just like it is) and NOT one big one (which it isn't) for the modules.
thomastaranowski
Thanks for the input guys. I've had another person recommend that I just make my own as well. I'm just getting started with board layouts, so it's good to know what the best practices are. It's nice to have at least an initial example to go from to make sure I'm doing it the right way. I'll start with the 5282 files ridge posted so that I'm not totally off in the weeds.
Chris' advice on the NB parts is good: If you keep 2 symbols (one for J1 and one for J2) they turn out to be quite a bit easier to wield in most schematics. I find the downside is that the two footpints must also then be separate in most layout packages. This is OK, with the BIG exception that the two footprints for J1 and J2 can then be moved inpendently which of course can't really happen if you want the Mod52XX to actually fit! So, when you position them, check, then check again that the offst from J1.1 to J2.1 is cool, then lock them down so they can't move inadvertently. This spacing is also something worth checking in a final review step since most built-in error checking won't catch it if one footprint gets bumped. For these reasons, I actually have J1 and J2 one footprint which also allows me to include one or two of the small mounting holes and some silkscreen graphics for the ethernet jack and the NB board edge. With one footprint, all this stuff moves as a unit. All this helps with the mechanical layout, but makes the schematic somewhat of a pain since often symbols for J1 and J2 want to wind up on different pages.....Basically choose your poison!
v8dave
Post by v8dave »
Ridgeglider wrote:With one footprint, all this stuff moves as a unit. All this helps with the mechanical layout, but makes the schematic somewhat of a pain since often symbols for J1 and J2 want to wind up on different pages....
I have them as 2 schematic parts that I can put on any sheet. This makes it easier to put all the memory mapped stuff on a different sheet and the IO on another. Makes it a lot less cluttered and means I can use A4 sheets instead of A3. But then, the software I have allows you to do this and not being familiar with Eagle not sure if you can do this but well worth the effort to find out.
The PCB part is one part complete with a 3D model of the MOD5234 (and 5270). This avoids the issue of alignment and positioning of the connectors.
Chris Ruff
Eagle, like any other layout program, allows a component to have sub-parts (think 7408 and-logic or LM324 op-amps).
So the module is a part with two 'gates' that are the connector strips
rhopf1
Post by rhopf1 »
v8dave,
Love the 3D, do you have these in step? Please post.
