Compiler errors with v2.9.2
When IPv4Only is enabled, and I try to rebuild the system, I get compiler errors in file nbiprintf.cpp about "IPADDR was not declared in this scope". Looks like the appropriate header file is not included when using IPv4Only.
Re: Compiler errors with v2.9.2
Yes we found that bug, its been fixed.
Submit a support request well give you the patch.
