Using AppName
Using AppName
In my Nano application I changed AppName from a fixed constant string to a variable. And while it works for
my application, neither AutoUpdate nor the Eclipse IDE show the string. I was curious why that is.
char AppName[64];
siprintf( AppName, "EXC v%s ser#%s",	FormatFWVersion(buf,true), SS->serial_no );
StartEthernet();
Re: Using AppName
In your code add:
extern const char *AppName;
const char * AppName;
char MyAppNameBuffer[64];
In your code:
AppName=MyAppNameBuffer;
And see if that fixes things...
Re: Using AppName
That worked. Thank you.
