Restarting code without flashing the device
v8dave
Post by v8dave »
Is there any way to restart a running application during debug instead of having to downloading and reflashing the device?
Sometimes when debugging I want to try something out more than once to check behavour and at present I have to download and restart the application each time. What would be nice is a way to RESET the programme to the start and start debugging again.
Can this be done?
Cheers,
Re: Restarting code without flashing the device
Yes. See the attached image. With this set when you re-run your debug configuration it just prompts you to quit the current session and starts over.
Tod is awesome. I didn't know that was there either.
aww shucks. Of course I should have given credit to Forrest . Not too long ago, I just happened to see his response to a post from two years back about this upcoming feature in Rel23_rc1.
v8dave
Post by v8dave »
Thanks Tod,
This sort of works but doesn't restart the code from the beginning. It just seems to reconnect the debugger, which for some stuff will work for me. Ideally I want a restart of the app without the reload.
I also don't see a way to load any updated code with this option selected. I have made changes and then rebuilt the code but not I can't see how to download this without switching this option off!!
Cheers,
You could call or jump to ForceReboot() from bsp.c
void ForceReboot()
   SetSR_IntLevel( 7 );
   sim.reset.rcr = 0x80;
The reset button???
v8dave
Post by v8dave »
At first I thought you was joking, then I realised that with the suggestion from Tod this would work and sure enough it does!!
Just need a way to download recompiled code without changing the check box option and I am in business but otherwise this is excellent suggestions.
Cheers all.
AutoUpdate?
To make it easy there's a button for it in the toolbar.
Also, you can automate it more via the external tools menu and using the command line version
See the \nburn\docs\NetBurnerPcTools\NetBurnerTools.pdf p 27 for full details but the summary is
AutoUpdate.exe -I<ipaddr> -F<filename> -R -A
v8dave
Post by v8dave »
Thanks Tod,
Because you have to select the file each time you use this, I'll investigate creating a new tool for it using the command line option.
Getting closer to the perfect setup I would like!! :o)
