Page 1 of 2
Multiple Defines errors when linking
Posted: Wed Dec 29, 2010 11:25 am
by kmcclure
I seem to be having a problem when it comes to the linker seeing multiple definition, I have gone through the project but can't seem to find where it is relinking in the same files. This problem has me stuck. :roll:
Any help would be greatly appreciated
Here is what I am seeing.
m68k-elf-g++ PortingCode\webfuncs.o PortingCode\utilfuncs.o PortingCode\timer.o PortingCode\testfuncs.o PortingCode\sysvar.o PortingCode\srec.o PortingCode\sfp.o PortingCode\rtc.o PortingCode\rssi_sm.o PortingCode\rssi.o PortingCode\proxy_sm.o PortingCode\power.o PortingCode\otamHtml.o ..\PortingCode\obj\webfuncs.o ..\PortingCode\obj\utilfuncs.o ..\PortingCode\obj\testfuncs.o ..\PortingCode\obj\rtc.o ..\PortingCode\obj\main.o ..\PortingCode\obj\htmldata.o ..\PortingCode\obj\formcode.o ..\PortingCode\obj\SNMPsetup.o ..\PortingCode\obj\AT25320.o ..\PortingCode\obj\ADS7830.o ..\PortingCode\obj\AD7414.o PortingCode\ntpclient.o PortingCode\minilzo.o PortingCode\main.o PortingCode\ioduOut.o PortingCode\ioduIn.o PortingCode\ioduBuffers.o PortingCode\iodu.o PortingCode\htmldata.o PortingCode\hello.o PortingCode\ftpd.o PortingCode\fpgabl.o PortingCode\formcode.o PortingCode\ebl.o PortingCode\eband-mib.o PortingCode\dheap.o PortingCode\debugPrintf.o PortingCode\atpc_sm.o PortingCode\atpcHtml.o PortingCode\atpc.o PortingCode\StopWatch.o PortingCode\SNMPsetup.o PortingCode\SFPhtml.o PortingCode\S25FL129.o PortingCode\RFinterface.o PortingCode\LMK30xx.o PortingCode\LIS33DE.o PortingCode\FECFPGA.o PortingCode\EBqspi.o PortingCode\DmaSerial.o PortingCode\CRC_CCITT_16.o PortingCode\AT45DB.o PortingCode\AT25320.o PortingCode\ADS7830.o PortingCode\ADF4156.o PortingCode\ADF4107.o PortingCode\AD7997.o PortingCode\AD7414.o htmldata.o -Wl,-Map=LR1000C.map -mcpu=5208 -Wl -Wl,-n -TC:\nburn\MOD5270\lib\MOD5270.ld -Wl,-RC:\nburn\MOD5270\lib\sys.ld -nostartfiles -Wl,--start-group,C:\nburn\lib\MOD5270.a C:\nburn\lib\MOD5270B.a C:\nburn\lib\NetBurner.a C:\nburn\lib\FatFile.a -Wl,--end-group -oLR1000C.elf
..\PortingCode\obj\webfuncs.o: In function `local_MON_SysStatus()':
C:\PortingCode/webfuncs.cpp:549: multiple definition of `local_MON_SysStatus()'
PortingCode\webfuncs.o:C:\nburn\NBEclipse\workspace\LR1000C\Release/..\PortingCode/webfuncs.cpp:550: first defined here
..\PortingCode\obj\webfuncs.o: In function `InitHistAgg':
C:\PortingCode/webfuncs.cpp:3999: multiple definition of `InitHistAgg'
PortingCode\webfuncs.o:C:\nburn\NBEclipse\workspace\LR1000C\Release/..\PortingCode/webfuncs.cpp:4000: first defined here
Re: Multiple Defines errors when linking
Posted: Wed Dec 29, 2010 12:58 pm
Did you create the project by importing files? Did you perhaps import the auto-generated htmldata.cpp file? That will cause problems if you did.
Posted: Wed Dec 29, 2010 5:09 pm
by kmcclure
Actually I did, it seems to be looking at both.
This is what I see now
I know it's a bit long.
It looks like it linking in twice so the memory size it twice what it should be
I will have to post the build in three parts because of length
**** Internal Builder is used for build               ****
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\SFPhtml.o ..\PortingCode\SFPhtml.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\srec.o ..\PortingCode\srec.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\ioduBuffers.o ..\PortingCode\ioduBuffers.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\power.o ..\PortingCode\power.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\otamHtml.o ..\PortingCode\otamHtml.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\AD7414.o ..\PortingCode\AD7414.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\main.o ..\PortingCode\main.cpp
..\PortingCode\main.cpp:83:2: warning: #warning
..\PortingCode\main.cpp:84:2: warning: #warning ################ Using MCF5270 ######################
..\PortingCode\main.cpp:85:2: warning: #warning
..\PortingCode\main.cpp:1018:2: warning: #warning %#%#%#%#% WatchDog is being enabled in software %#%#%#%#%
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\ADF4156.o ..\PortingCode\ADF4156.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\AT25320.o ..\PortingCode\AT25320.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\ebl.o ..\PortingCode\ebl.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\htmldata.o ..\PortingCode\htmldata.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\rtc.o ..\PortingCode\rtc.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\formcode.o ..\PortingCode\formcode.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\ftpd.o ..\PortingCode\ftpd.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\debugPrintf.o ..\PortingCode\debugPrintf.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\ioduOut.o ..\PortingCode\ioduOut.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\fpgabl.o ..\PortingCode\fpgabl.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\rssi.o ..\PortingCode\rssi.cpp
..\PortingCode\rssi.cpp:542: warning: 'rssi_state_t rssistrtol(char*)' defined but not used
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\atpc_sm.o ..\PortingCode\atpc_sm.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\LIS33DE.o ..\PortingCode\LIS33DE.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\testfuncs.o ..\PortingCode\testfuncs.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\rssi_sm.o ..\PortingCode\rssi_sm.cpp
..\PortingCode\rssi_sm.cpp:80: warning: 'void rssiState_Default(rssiContext*)' defined but not used
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\atpc.o ..\PortingCode\atpc.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\hello.o ..\PortingCode\hello.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\SNMPsetup.o ..\PortingCode\SNMPsetup.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\AD7997.o ..\PortingCode\AD7997.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\iodu.o ..\PortingCode\iodu.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\sfp.o ..\PortingCode\sfp.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\AT45DB.o ..\PortingCode\AT45DB.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\minilzo.o ..\PortingCode\minilzo.cpp
..\PortingCode\minilzo.cpp: In function 'lzo_bool ptr_check()':
..\PortingCode\minilzo.cpp:1037: warning: NULL used in arithmetic
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\StopWatch.o ..\PortingCode\StopWatch.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\CRC_CCITT_16.o ..\PortingCode\CRC_CCITT_16.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\utilfuncs.o ..\PortingCode\utilfuncs.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\proxy_sm.o ..\PortingCode\proxy_sm.cpp
..\PortingCode\proxy_sm.cpp:57: warning: 'void proxyState_helloSignal(proxyContext*)' defined but not used
..\PortingCode\proxy_sm.cpp:67: warning: 'void proxyState_keepalive(proxyContext*)' defined but not used
..\PortingCode\proxy_sm.cpp:77: warning: 'void proxyState_linkDown(proxyContext*)' defined but not used
..\PortingCode\proxy_sm.cpp:112: warning: 'void proxyState_Default(proxyContext*)' defined but not used
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\S25FL129.o ..\PortingCode\S25FL129.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\ntpclient.o ..\PortingCode\ntpclient.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\LMK30xx.o ..\PortingCode\LMK30xx.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\ioduIn.o ..\PortingCode\ioduIn.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\EBqspi.o ..\PortingCode\EBqspi.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\sysvar.o ..\PortingCode\sysvar.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\webfuncs.o ..\PortingCode\webfuncs.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\RFinterface.o ..\PortingCode\RFinterface.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\timer.o ..\PortingCode\timer.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\eband-mib.o ..\PortingCode\eband-mib.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\DmaSerial.o ..\PortingCode\DmaSerial.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\atpcHtml.o ..\PortingCode\atpcHtml.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\dheap.o ..\PortingCode\dheap.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\ADF4107.o ..\PortingCode\ADF4107.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\FECFPGA.o ..\PortingCode\FECFPGA.cpp
comphtml C:\nburn\NBEclipse\workspace\LR1000\PortingCode\html -ohtmldata.cpp
Posted: Wed Dec 29, 2010 5:10 pm
by kmcclure
Reading files from C:\nburn\NBEclipse\workspace\LR1000\PortingCode\html and compressing them into htmldata.cpp
Processing /alarms.htm
New function WebF_OPS_AlarmList # 1
 1793 bytes
Processing /AlignBER.htm 628 bytes
Processing /AlignBERBarsBot.htm
New function Web_BB_BER_BotRefresh # 2
New function Web_BB_BER_Bar_Hr # 3
New function Web_BB_BER_Started # 4
New function Web_BB_BER_HistWidth # 5
 1645 bytes
Processing /AlignBERBarsTop.htm
New function Web_BB_BER_TopRefresh # 6
New function Web_FEC_BER_Raw # 7
New function Web_IF_RSSI1 # 8
New function Web_BB_BER_Bar # 9
New function Web_BB_BER_Elapsed # 10
New function Web_BB_BER_CumBERT # 11
New function Web_BB_BER_CumNoSync # 12
 2002 bytes
Processing /AlignBERpost.htm
New function Web_CON_AccFactory # 13
New function WebF_BB_BER_Mode # 14
New function WebF_BB_BERaction # 15
New function WebF_BB_BER_Histogram # 16
 2221 bytes
Processing /AlignRSSI.htm 525 bytes
Processing /AlignRSSIBars.htm
New function Web_IF_RSSIaidMin # 17
New function Web_IF_V_RSSI # 18
New function Web_IF_RSSIaidMax # 19
New function Web_IF_RSSI1_BAR # 20
New function Web_IF_RSSI1_BAR_LOW # 21
New function Web_IF_RSSI1_BAR_HIGH # 22
 1845 bytes
Processing /AlignRSSIpost.htm 691 bytes
Processing /AlreadyFull.htm 624 bytes
Processing /AnalogRegs.htm
New function Web_FAC_Band # 23
New function Web_ADF4107_Regs # 24
New function WebF_ADF4107_Freq # 25
New Variable  Web_ADF4156_Regs(fd,1) # 1
New Variable  WebF_ADF4156_Freq(fd,1) # 2
New Variable  Web_ADF4156_Regs(fd,2) # 3
New Variable  WebF_ADF4156_Freq(fd,2) # 4
New function Web_CON_InputError4 # 26
New Variable  Web_LMK30xx_Regs(fd,1) # 5
New Variable  Web_LMK30xx_Regs(fd,2) # 6
 2948 bytes
Processing /atpc.htm
New function WebF_ATPC_enabled # 27
New function WebF_local_antenna # 28
New function WebF_remote_antenna # 29
New function WebF_link_distance # 30
New function WebF_ATPC_local_locus # 31
New function WebF_ATPC_remote_locus # 32
New function WebF_FSPL_print # 33
New function WebF_RSL_print # 34
New function WebF_locus_txPower # 35
Found function Web_CON_AccFactory # 13
New function WebF_remote_threshold # 36
 7366 bytes
Processing /banner.htm
New function Web_OPS_BannerRefresh # 37
New function Web_OPS_Title_Browser # 38
New function Web_OPS_Logo # 39
New function Web_OPS_Banner # 40
New function Web_FAC_ModNo # 41
New function Web_FAC_SerNo_Wrap # 42
New function Web_INS_CLLI # 43
New function Web_ATPC_status # 44
 1435 bytes
Processing /BERTreport.htm
Found function Web_OPS_Title_Browser # 38
New function Web_OPS_Icon # 45
New function Web_OPS_OwnIPaddr # 46
Found function Web_BB_BER_Started # 4
Found function Web_BB_BER_Elapsed # 10
Found function Web_BB_BER_CumBERT # 11
Found function Web_BB_BER_CumNoSync # 12
New function Web_CFG_BERTgreenThresh # 47
New function Web_BB_BER_IntervalReport # 48
Found function Web_OPS_OwnIPaddr # 46
 3832 bytes
Processing /CER.htm
New function Web_FEC_CER_Raw # 49
 621 bytes
Processing /config.htm
New function Web_CON_Page_ConfigEnter # 50
New function Web_CFG_LineRate # 51
New function Web_CFG_CoData # 52
New function Web_CFG_Authen # 53
New function Web_CFG_Language # 54
New function Web_INS_Gateway # 55
New function Web_INS_CoIPaddr # 56
New function Web_INS_CoIPport # 57
New function Web_INS_TftpIp # 58
New function Web_CFG_TimeSource # 59
New function Web_BB_RPS_EnDis # 60
New function Web_BB_RPS_ThreshNdx # 61
New Variable  BB_RPS_DlyStop # 7
New Variable  BB_RPS_DlyStart # 8
New function Web_CON_DivPortExp # 62
New Variable  Web_EXT_Panel_RelayName(fd,1) # 9
New function Web_CFG_AlarmRelay1 # 63
New Variable  Web_EXT_Panel_RelayName(fd,2) # 10
New function Web_CFG_AlarmRelay2 # 64
New Variable  Web_EXT_Panel_RelayName(fd,3) # 11
New function Web_CFG_AlarmRelay3 # 65
New function Web_CFG_RSSIredThresh # 66
New function Web_CFG_RSSIgreenThresh # 67
Found function Web_CFG_BERTgreenThresh # 47
New function Web_CFG_AlarmStatus # 68
New function Web_CFG_SMTP_IP # 69
New function Web_CFG_SMTP_User # 70
New function Web_CFG_AlarmUsers # 71
 8524 bytes
Processing /configEnter.htm
New function WebF_CFG_Authen # 72
New function Web_CFG_ChangePW # 73
New function WebF_CFG_RSSIredThresh # 74
New function WebF_CFG_RSSIgreenThresh # 75
New function WebF_CFG_RSSIthreshUnits # 76
New function WebF_CFG_BERTgreenThresh # 77
New function WebF_BB_RPS_EnDis # 78
New function WebF_BB_RPS_ThreshNdx # 79
New function WebF_BB_RPS_DlyStop # 80
New function WebF_BB_RPS_DlyStart # 81
New function Web_CON_AccInstall # 82
New function WebF_IF_TxMute_TimeOut # 83
New function WebF_IF_TxMute_TimeOutLen # 84
New function Web_Proxy_Enable # 85
New function WebF_INS_IPaddr # 86
New function WebF_INS_IPport # 87
New function WebF_INS_Gateway # 88
New function WebF_INS_CoIPaddr # 89
New function WebF_INS_CoIPport # 90
New function WebF_INS_TftpIp # 91
New function WebF_CFG_NtpServer # 92
New function WebF_CFG_NtpUTC # 93
New function Web_CON_InputError2 # 94
Found function Web_CON_DivPortExp # 62
Found Variable  Web_EXT_Panel_RelayName(fd,1) # 9
New function WebF_CFG_AlarmRelay1 # 95
Found Variable  Web_EXT_Panel_RelayName(fd,2) # 10
New function WebF_CFG_AlarmRelay2 # 96
Found Variable  Web_EXT_Panel_RelayName(fd,3) # 11
New function WebF_CFG_AlarmRelay3 # 97
New function WebF_CFG_AlarmStatus # 98
New function WebF_CFG_EmailStatus # 99
New function WebF_CFG_SMTP_IP # 100
New function WebF_CFG_SMTP_User # 101
New function WebF_CFG_SMTP_PW # 102
New function WebF_CFG_SMTP_Sender # 103
New function WebF_CFG_AlarmUsers # 104
New function Web_CFG_SMTP_TestResult # 105
 13019 bytes
Processing /contents.htm
New function Web_OPS_Title_Content # 106
New function Web_CON_Page_OpStatus # 107
New function Web_CON_Page_FECFPGAStats # 108
New function Web_CON_Page_Detail # 109
New function Web_CON_Page_Control # 110
New function Web_CON_Page_Config # 111
New function Web_CON_Page_Install # 112
New function Web_CON_Page_Factory # 113
New function Web_CON_Page_History # 114
New function Web_CON_Page_ATPC # 115
New function Web_CON_Page_Help # 116
New function Web_CON_Page_Login # 117
New function Web_OPS_UserIPaddr # 118
New function Web_FAC_ContRev # 119
 4886 bytes
Processing /controlEngr.htm
New function Web_CTL_PwrCtlSourceFEC # 120
New function WebF_CON_OpTxPower # 121
New function Web_FAC_MinPower # 122
New function Web_FAC_MaxPower # 123
New function WebF_CTL_IFtxMute # 124
New function WebF_CTL_IFtxDataCW # 125
New function Web_CON_InputError1 # 126
New function Web_CON_DivPearl # 127
New function WebF_PWR_RF_Shutdown # 128
New function WebF_CTL_Relay1 # 129
New function WebF_CTL_Relay2 # 130
New function WebF_CTL_Relay3 # 131
New function WebF_BB_LoopbackLen # 132
New function WebF_CON_LoopTrib # 133
New function WebF_CON_LoopLink # 134
New function WebF_CON_LoopDis # 135
New function Web_CON_DivLoopback # 136
New function Web_FAC_SFPisPresentOrFac # 137
New function Web_CON_DivRecovery # 138
 14279 bytes
Processing /debug.htm
New function Web_FAC_ContRevAll # 139
New function Web_DEB_Level # 140
New function Web_DEB_WatchdogSw # 141
New function Web_DEB_WatchdogHw # 142
New function Web_DEB_Interrupts # 143
New function Web_DEB_WatchdogSwWho # 144
New function Web_DEB_DebugData # 145
 2176 bytes
Processing /DebugInfo.htm
New function Web_CON_Help_Info # 146
 611 bytes
Processing /eband08.css 1037 bytes
Processing /EBLProgUpload.htm
Found function Web_INS_TftpIp # 58
New function WebF_INS_TftpFilename # 147
Found function Web_CON_InputError4 # 26
 4700 bytes
Processing /EBLUploadStatus.htm
New function Web_INS_EBLUploadStatus # 148
 617 bytes
Processing /factory.htm
New function Web_CON_Page_FactoryEnter # 149
Found function Web_FAC_ModNo # 41
New function Web_FAC_Family # 150
New function Web_FAC_Band_Rates # 151
New function Web_FAC_PartNo # 152
New function Web_FAC_ModGen # 153
New function Web_FAC_ModRel # 154
New function Web_FAC_SerNo # 155
New function Web_FAC_MACaddr # 156
Found function Web_FAC_MaxPower # 123
Found function Web_FAC_MinPower # 122
New function Web_FAC_BBHwRev # 157
New function Web_FEC_FPGASwRev # 158
New function Web_FAC_ContHwRev # 159
Found function Web_FAC_ContRevAll # 139
New function Web_FAC_IFHwRev # 160
New function Web_FAC_IFRev # 161
New function Web_FAC_RFTXHwRev # 162
New function Web_FAC_RFRXHwRev # 163
New function Web_MON_WhyStarted # 164
New function Web_FAC_SFPmodel # 165
New Variable  OPS_BornOn # 12
 6604 bytes
Processing /factoryEnter.htm
New function WebF_FAC_ModNo # 166
New function WebF_FAC_PartNo # 167
New function WebF_FAC_SerNo # 168
New function WebF_FAC_ModGen # 169
New function WebF_FAC_ModRel # 170
New function WebF_FAC_MaxPower # 171
New function WebF_FAC_MinPower # 172
New function Web_FAC_BandValid # 173
New function WebF_FAC_Band # 174
Found function Web_FAC_BBHwRev # 157
New function WebF_FAC_ContHwRev # 175
New function WebF_FAC_IFHwRev # 176
New function WebF_FAC_RFTXHwRev # 177
New function WebF_FAC_RFRXHwRev # 178
Found function Web_FEC_FPGASwRev # 158
Found function Web_CON_InputError1 # 126
New function WebF_FAC_TxPower # 179
New function WebF_FAC_TxPower_Filename # 180
New function Web_CON_InputError3 # 181
New function WebF_FAC_RSSI # 182
New function WebF_FAC_RSSI_Filename # 183
Found function Web_CON_InputError3 # 181
New function WebF_RF_Tx_TT # 184
New function WebF_FAC_TempCompPower # 185
 11332 bytes
Processing /FECFPGA.htm
New function Web_FEC_FECTest_1 # 186
New function WebF_FEC_Test1MaxCycles # 187
 2349 bytes
Processing /FECFPGAregs.htm
New function Web_FEC_CntPayloadDrop # 188
New function Web_FEC_CntLinkDrop # 189
New function Web_FEC_NoErrors # 190
New function Web_FEC_CorrErros # 191
New function Web_FEC_UncorrErros # 192
New function Web_FEC_AllMem # 193
 4353 bytes
Processing /FECFPGAserial.htm
New function WebF_FEC_Usage # 194
 1723 bytes
Processing /FECFPGAserialBigBlock.htm
New function WebF_FEC_BigBlockStats # 195
 628 bytes
Processing /FECFPGAserialResponse.htm
New function Web_FEC_SerialResponse # 196
 677 bytes
Processing /FECFPGAStats.htm
New function Web_FEC_LinkStats # 197
New function Web_FEC_LastES # 198
 1724 bytes
Processing /FECFPGA_TestResult_1.htm
Found function Web_FEC_CntPayloadDrop # 188
Found function Web_FEC_CntLinkDrop # 189
Found function Web_FEC_NoErrors # 190
Found function Web_FEC_CorrErros # 191
Found function Web_FEC_UncorrErros # 192
New function Web_FEC_ActiveTest_1 # 199
New function Web_FEC_Test1Value # 200
New function Web_FEC_Test1Cycles # 201
Found function Web_FEC_BER_Raw # 7
Found function Web_FEC_CER_Raw # 49
New function Web_FEC_ResetTimeManCold # 202
New function Web_FEC_ResetCounter # 203
New function Web_FEC_ResetTimeLast # 204
 1959 bytes
Processing /FPGAUpload.htm
New function WebF_INS_FPGAFilename # 205
New function Web_INS_FPGAImage # 206
New function Web_INS_FPGAImage2 # 207
New Variable  Web_INS_FPGA_Files(fd,0) # 13
New Variable  Web_INS_FPGA_Files(fd,1) # 14
New Variable  Web_INS_FPGA_Files(fd,2) # 15
New Variable  Web_INS_FPGA_Files(fd,3) # 16
 4396 bytes
Processing /FPGAUploadStatus.htm
New function Web_INS_FPGAUploadStatus # 208
 619 bytes
Processing /genericError.htm
New function WebGenericError # 209
 617 bytes
Processing /help_ADC.htm 1491 bytes
Processing /help_EBCC.htm
New function Web_FAC_ModNo2 # 210
 1293 bytes
Processing /HistCont.htm
New function WebF_HIS_Date1 # 211
New function WebF_HIS_Date2 # 212
New function Web_HIS_LogControl # 213
 6411 bytes
Processing /histDownload.htm
Found function WebF_INS_TftpFilename # 147
 2797 bytes
Processing /histgraphRSSI.htm
New function Web_HIS_dataRSSI # 214
New function Web_HIS_GraphSamples # 215
New function Web_HIS_RngTxCtl # 216
New function Web_HIS_RngTxPwr # 217
New function Web_HIS_RngRSSI # 218
 5314 bytes
Processing /histgraphTemps.htm
New function Web_HIS_dataTemps # 219
Found function Web_HIS_GraphSamples # 215
 4852 bytes
Processing /history.htm 530 bytes
Processing /histtxt.htm
New function Web_HIS_TextReport # 220
 1868 bytes
Processing /HWdevel.htm
New Variable  Web_AD7997_Regs(fd,0,1,0) # 17
New Variable  Web_AD7997_Regs(fd,0,1,1) # 18
New Variable  Web_AD7997_Regs(fd,1,1,0) # 19
New Variable  Web_AD7997_Regs(fd,1,1,1) # 20
New Variable  Web_AD7997_Regs(fd,0,2,0) # 21
New Variable  Web_AD7997_Regs(fd,0,2,1) # 22
New Variable  Web_AD7997_Regs(fd,1,2,0) # 23
New Variable  Web_AD7997_Regs(fd,1,2,1) # 24
New Variable  Web_AD7997_Regs(fd,0,3,0) # 25
New Variable  Web_AD7997_Regs(fd,0,3,1) # 26
New Variable  Web_AD7997_Regs(fd,1,3,0) # 27
New Variable  Web_AD7997_Regs(fd,1,3,1) # 28
New Variable  Web_AD7997_Regs(fd,0,4,0) # 29
New Variable  Web_AD7997_Regs(fd,0,4,1) # 30
New Variable  Web_AD7997_Regs(fd,1,4,0) # 31
New Variable  Web_AD7997_Regs(fd,1,4,1) # 32
New Variable  Web_AD7997_Regs(fd,0,5,0) # 33
New Variable  Web_AD7997_Regs(fd,0,5,1) # 34
New Variable  Web_AD7997_Regs(fd,1,5,0) # 35
New Variable  Web_AD7997_Regs(fd,1,5,1) # 36
New Variable  Web_AD7997_Regs(fd,0,6,0) # 37
New Variable  Web_AD7997_Regs(fd,0,6,1) # 38
New Variable  Web_AD7997_Regs(fd,1,6,0) # 39
New Variable  Web_AD7997_Regs(fd,1,6,1) # 40
New Variable  Web_AD7997_Regs(fd,0,7,0) # 41
New Variable  Web_AD7997_Regs(fd,0,7,1) # 42
New Variable  Web_AD7997_Regs(fd,1,7,0) # 43
New Variable  Web_AD7997_Regs(fd,1,7,1) # 44
New Variable  Web_AD7997_Regs(fd,0,8,0) # 45
New Variable  Web_AD7997_Regs(fd,0,8,1) # 46
New Variable  Web_AD7997_Regs(fd,1,8,0) # 47
New Variable  Web_AD7997_Regs(fd,1,8,1) # 48
New function Web_ACC_Polarity # 221
New function Web_ACC_Regs # 222
New function Web_ACC_Gs # 223
New function Web_BB_MiscHw # 224
 5642 bytes
Processing /images/Alarm.wav 5110 bytes
Processing /images/banner_ADC.jpg 1565 bytes
Processing /images/banner_EBCC.jpg 4365 bytes
Processing /images/bar0.GIF 856 bytes
Processing /images/bar1.GIF 870 bytes
Processing /images/bar10.GIF 856 bytes
Processing /images/bar11.GIF 848 bytes
Processing /images/bar12.GIF 866 bytes
Processing /images/bar13.GIF 856 bytes
Processing /images/bar2.GIF 874 bytes
Processing /images/bar3.GIF 875 bytes
Processing /images/bar4.GIF 876 bytes
Processing /images/bar5.GIF 876 bytes
Processing /images/bar6.GIF 878 bytes
Processing /images/bar7.GIF 875 bytes
Processing /images/bar8.GIF 874 bytes
Processing /images/bar9.GIF 869 bytes
Processing /images/blugrn.gif 1569 bytes
Processing /images/grybmp.gif 1443 bytes
Processing /images/icon_ADC.ico 766 bytes
Processing /images/icon_EBCC.ico 766 bytes
Processing /images/logo_ADC.jpg 893 bytes
Processing /images/logo_EBCC.gif 2367 bytes
Processing /images/radio_off.GIF 853 bytes
Processing /images/radio_on.GIF 861 bytes
Processing /images/StatusGray.GIF 1040 bytes
Processing /images/StatusGreen.GIF 985 bytes
Processing /images/StatusRed.GIF 991 bytes
Processing /images/StatusYellow.GIF 992 bytes
Processing /index.htm
 1266 bytes
Processing /install.htm
Found function Web_INS_CLLI # 43
New function Web_INS_City # 225
New function Web_INS_State # 226
New function Web_INS_Location # 227
New function Web_INS_Equip # 228
New function Web_INS_Lat # 229
New function Web_INS_Lon # 230
New function Web_INS_Cust_Asset # 231
New function Web_INS_Cust_SerNo # 232
New function Web_CON_DivCiena # 233
Found function Web_CON_DivCiena # 233
New function Web_INS_AttachedDevice # 234
New function Web_INS_CoCLLI # 235
New function Web_INS_CoCity # 236
New function Web_INS_CoState # 237
New function Web_INS_CoLocation # 238
New function Web_INS_CoEquip # 239
New function Web_INS_CoLat # 240
New function Web_INS_CoLon # 241
New function Web_INS_CoCust_Asset # 242
New function Web_INS_CoCust_SerNo # 243
New function Web_CON_Page_BERT # 244
New function Web_CON_Page_InstallEnter # 245
New function Web_CON_Page_RSSI # 246
New function Web_CON_Page_SoftwareUpdate # 247
New function Web_CON_Page_FPGAUpdate # 248
 9377 bytes
Processing /installEnter.htm
New function WebF_INS_CLLI # 249
New function WebF_INS_City # 250
New function WebF_INS_State # 251
New function WebF_INS_Location # 252
New function WebF_INS_Equip # 253
New function WebF_INS_Lat # 254
New function WebF_INS_Lon # 255
New function WebF_INS_Cust_Asset # 256
New function WebF_INS_Cust_SerNo # 257
New function WebF_INS_AttachedDevice # 258
New function WebF_INS_CoCLLI # 259
New function WebF_INS_CoCity # 260
New function WebF_INS_CoState # 261
New function WebF_INS_CoLocation # 262
New function WebF_INS_CoEquip # 263
New function WebF_INS_CoLat # 264
New function WebF_INS_CoLon # 265
New function WebF_INS_CoCust_Asset # 266
New function WebF_INS_CoCust_SerNo # 267
Found function Web_CON_InputError2 # 94
New function Web_CFG_SNMPparams # 268
New function WebF_SNMP_ReadComm # 269
New function WebF_SNMP_WriteComm # 270
New function WebF_SNMP_TrapRcvr # 271
 5513 bytes
Processing /jsgraph.js 12994 bytes
Processing /jsgraphReal.js 64334 bytes
Processing /logFail.htm 804 bytes
Processing /manageSettings.htm
 1160 bytes
Processing /monitor.htm
New function Web_MON_SysStatus # 272
New function Web_BB_Loopback # 273
New function Web_CTL_PwrCtlSource # 274
New function Web_FEC_BER # 275
Found function Web_IF_RSSI1 # 8
New function Web_IF_RSSI1_engr2 # 276
New function Web_MON_UpTime # 277
New Variable  Web_SYS_Temps(fd,eTEMP_BB) # 49
New Variable  Web_SYS_Temps(fd,eTEMP_SFP) # 50
New Variable  Web_SYS_Temps(fd,eTEMP_RF) # 51
New Variable  Web_SYS_Temps(fd,eTEMP_IF) # 52
New Variable  Web_SYS_Temps(fd,eTEMP_PWR1) # 53
New function Web_PWR_Present # 278
New Variable  Web_SYS_Voltages(fd,ePWR_MonNeg48V) # 54
New Variable  Web_SYS_Voltages(fd,ePWR_MonNeg5V) # 55
New Variable  Web_SYS_Voltages(fd,ePWR_Mon1p0V) # 56
New Variable  Web_SYS_Voltages(fd,ePWR_Mon3p3V) # 57
New Variable  Web_SYS_Voltages(fd,ePWR_Mon6p0V) # 58
New Variable  Web_SYS_Voltages(fd,ePWR_Mon12V) # 59
New Variable  Web_SYS_Voltages(fd,ePWR_Mon5p0V) # 60
New Variable  Web_SYS_Voltages(fd,ePWR_Mon2p5V) # 61
New Variable  Web_SYS_Voltages(fd,ePWR_Mon1p2V) # 62
New Variable  Web_SYS_Voltages(fd,ePWR_MonPoENeg48V) # 63
New function Web_IF_TxModemLock # 279
New function Web_IF_Tx_Mute # 280
New function Web_IF_TxDataCW # 281
New function Web_IF_TxPowerCtl # 282
New function Web_RF_SerialIntf # 283
New function Web_LO_LockDetect # 284
New function Web_BB_GBICPres # 285
New function Web_BB_GBIC_LOS # 286
New function Web_PIC_GBIC_TxPwr # 287
New function Web_PIC_GBIC_RxPwr # 288
New function Web_FEC_TxStatus # 289
New function Web_FEC_RxStatus # 290
Found function Web_ACC_Polarity # 221
Found function Web_ACC_Regs # 222
Found function Web_ACC_Gs # 223
New Variable  Web_EXT_Panel_Relay(fd,1) # 64
New Variable  Web_EXT_Panel_Relay(fd,2) # 65
New Variable  Web_EXT_Panel_Relay(fd,3) # 66
New Variable  Web_EXT_Panel_InName(fd,1) # 67
New Variable  Web_EXT_Panel_In(fd,1) # 68
New Variable  Web_EXT_Panel_InName(fd,2) # 69
New Variable  Web_EXT_Panel_In(fd,2) # 70
New Variable  Web_EXT_Panel_InName(fd,3) # 71
New Variable  Web_EXT_Panel_In(fd,3) # 72
New Variable  Web_EXT_Panel_InName(fd,4) # 73
New Variable  Web_EXT_Panel_In(fd,4) # 74
New function Web_MON_OOB_Data # 291
 13257 bytes
Processing /MyHwRegs.htm 5 bytes
Processing /OpenForWrite.htm
New function Web_CON_WriteAccess # 292
 710 bytes
Processing /opstatus.htm
New function Web_MON_SysStatus_IMG # 293
Found function Web_MON_SysStatus # 272
New function Web_Remote_Status_IMG # 294
New function Web_Remote_Status # 295
New function Web_BB_TRIBUTARY_IMG # 296
New function Web_BB_TRIBUTARY_INPUT # 297
New function Web_Remote_Tributary_IMG # 298
New function Web_Remote_Tributary # 299
New function Web_RF_PowerLevel_IMG # 300
New function Web_RF_PowerLevel # 301
New function Web_Remote_Power_IMG # 302
New function Web_Remote_Power # 303
New function Web_IF_RSSI1_IMG # 304
New function Web_Remote_RSSI_IMG # 305
New function Web_Remote_RSSI # 306
New function Web_FEC_BER_IMG # 307
New function Web_FEC_BER2 # 308
New function Web_Remote_BER_IMG # 309
New function Web_Remote_BER # 310
Found function Web_FAC_Band # 23
New function Web_OPS_CoBand # 311
Found function Web_INS_CoCLLI # 235
New function Web_Remote_IPaddr # 312
Found function Web_MON_UpTime # 277
New function Web_Remote_UpTime # 313
New function WebF_OPS_Alarms # 314
New function Web_OPS_Time # 315
 7520 bytes
Processing /otam.css 823 bytes
Processing /otam.htm
New function Web_OTAM_statout # 316
New function Web_OTAM_statin # 317
 1580 bytes
Processing /OwnRadio.js 1866 bytes
Processing /ProgUpload.htm
 2932 bytes
Processing /PWmod.htm
 1666 bytes
Processing /RFxcvr.htm
Found function Web_OPS_Icon # 45
New function Web_FAC_RFxcvr_Data # 318
 396 bytes
Processing /SFPread.htm
New function Web_FAC_SFPdetails # 319
New function Web_FAC_SFPdetails_T # 320
New function Web_FAC_SFPdetails_X # 321
New function Web_FAC_SFPallRegs_T # 322
New function Web_FAC_SFPallRegs_X # 323
 4033 bytes
Processing /StatusLites.htm
New function Web_OPS_Title_Short # 324
New function Web_OPS_StatusLitesStatus # 325
New function Web_OPS_StatusLites # 326
 2912 bytes
Processing /StayAlive.htm
New function Web_CON_AuthLevel_js # 327
 681 bytes
Processing /SysTime.htm
Found function Web_OPS_Time # 315
 645 bytes
Processing /tbs.htm 590 bytes
Processing /TFTPstatus.htm
New function Web_INS_TftpXferStatus # 328
 619 bytes
Processing /TxPwrCtl.htm
Found function Web_RF_PowerLevel # 301
 602 bytes
Processing /TxPwrCtl2.htm
New function Web_RF_PowerLevel2 # 329
 605 bytes
Overflow !
Overflow !
Result counts = 511 total_ends :256
111495 bytes out of 166546 original encode out of 318809 total original
Found function WebF_OPS_AlarmList # 1
 1793 bytes
Found function Web_BB_BER_BotRefresh # 2
Found function Web_BB_BER_Bar_Hr # 3
Found function Web_BB_BER_HistWidth # 5
 1645 bytes
Posted: Wed Dec 29, 2010 5:12 pm
by kmcclure
Found function Web_BB_BER_TopRefresh # 6
Found function Web_BB_BER_Bar # 9
 2002 bytes
Found function WebF_BB_BER_Mode # 14
Found function WebF_BB_BERaction # 15
Found function WebF_BB_BER_Histogram # 16
 2221 bytes
Found function Web_IF_RSSIaidMin # 17
Found function Web_IF_V_RSSI # 18
Found function Web_IF_RSSIaidMax # 19
Found function Web_IF_RSSI1_BAR # 20
Found function Web_IF_RSSI1_BAR_LOW # 21
Found function Web_IF_RSSI1_BAR_HIGH # 22
 1845 bytes
Found function Web_ADF4107_Regs # 24
Found function WebF_ADF4107_Freq # 25
Found Variable  Web_ADF4156_Regs(fd,1) # 1
Found Variable  WebF_ADF4156_Freq(fd,1) # 2
Found Variable  Web_ADF4156_Regs(fd,2) # 3
Found Variable  WebF_ADF4156_Freq(fd,2) # 4
Found Variable  Web_LMK30xx_Regs(fd,1) # 5
Found Variable  Web_LMK30xx_Regs(fd,2) # 6
 2948 bytes
Found function WebF_ATPC_enabled # 27
Found function WebF_local_antenna # 28
Found function WebF_remote_antenna # 29
Found function WebF_link_distance # 30
Found function WebF_ATPC_local_locus # 31
Found function WebF_ATPC_remote_locus # 32
Found function WebF_FSPL_print # 33
Found function WebF_RSL_print # 34
Found function WebF_locus_txPower # 35
Found function WebF_remote_threshold # 36
 7366 bytes
Found function Web_OPS_BannerRefresh # 37
Found function Web_OPS_Logo # 39
Found function Web_OPS_Banner # 40
Found function Web_FAC_SerNo_Wrap # 42
Found function Web_ATPC_status # 44
 1435 bytes
Found function Web_BB_BER_IntervalReport # 48
 3832 bytes
Processing /CER.htm
 621 bytes
Found function Web_CON_Page_ConfigEnter # 50
Found function Web_CFG_LineRate # 51
Found function Web_CFG_CoData # 52
Found function Web_CFG_Authen # 53
Found function Web_CFG_Language # 54
Found function Web_INS_Gateway # 55
Found function Web_INS_CoIPaddr # 56
Found function Web_INS_CoIPport # 57
Found function Web_CFG_TimeSource # 59
Found function Web_BB_RPS_EnDis # 60
Found function Web_BB_RPS_ThreshNdx # 61
Found Variable  BB_RPS_DlyStop # 7
Found Variable  BB_RPS_DlyStart # 8
Found function Web_CFG_AlarmRelay1 # 63
Found function Web_CFG_AlarmRelay2 # 64
Found function Web_CFG_AlarmRelay3 # 65
Found function Web_CFG_RSSIredThresh # 66
Found function Web_CFG_RSSIgreenThresh # 67
Found function Web_CFG_AlarmStatus # 68
Found function Web_CFG_SMTP_IP # 69
Found function Web_CFG_SMTP_User # 70
Found function Web_CFG_AlarmUsers # 71
 8524 bytes
Found function WebF_CFG_Authen # 72
Found function Web_CFG_ChangePW # 73
Found function WebF_CFG_RSSIredThresh # 74
Found function WebF_CFG_RSSIgreenThresh # 75
Found function WebF_CFG_RSSIthreshUnits # 76
Found function WebF_CFG_BERTgreenThresh # 77
Found function WebF_BB_RPS_EnDis # 78
Found function WebF_BB_RPS_ThreshNdx # 79
Found function WebF_BB_RPS_DlyStop # 80
Found function WebF_BB_RPS_DlyStart # 81
Found function Web_CON_AccInstall # 82
Found function WebF_IF_TxMute_TimeOut # 83
Found function WebF_IF_TxMute_TimeOutLen # 84
Found function Web_Proxy_Enable # 85
Found function WebF_INS_IPaddr # 86
Found function WebF_INS_IPport # 87
Found function WebF_INS_Gateway # 88
Found function WebF_INS_CoIPaddr # 89
Found function WebF_INS_CoIPport # 90
Found function WebF_INS_TftpIp # 91
Found function WebF_CFG_NtpServer # 92
Found function WebF_CFG_NtpUTC # 93
Found function WebF_CFG_AlarmRelay1 # 95
Found function WebF_CFG_AlarmRelay2 # 96
Found function WebF_CFG_AlarmRelay3 # 97
Found function WebF_CFG_AlarmStatus # 98
Found function WebF_CFG_EmailStatus # 99
Found function WebF_CFG_SMTP_IP # 100
Found function WebF_CFG_SMTP_User # 101
Found function WebF_CFG_SMTP_PW # 102
Found function WebF_CFG_SMTP_Sender # 103
Found function WebF_CFG_AlarmUsers # 104
Found function Web_CFG_SMTP_TestResult # 105
 13019 bytes
Found function Web_OPS_Title_Content # 106
Found function Web_CON_Page_OpStatus # 107
Found function Web_CON_Page_FECFPGAStats # 108
Found function Web_CON_Page_Detail # 109
Found function Web_CON_Page_Control # 110
Found function Web_CON_Page_Config # 111
Found function Web_CON_Page_Install # 112
Found function Web_CON_Page_Factory # 113
Found function Web_CON_Page_History # 114
Found function Web_CON_Page_ATPC # 115
Found function Web_CON_Page_Help # 116
Found function Web_CON_Page_Login # 117
Found function Web_OPS_UserIPaddr # 118
Found function Web_FAC_ContRev # 119
 4886 bytes
Found function Web_CTL_PwrCtlSourceFEC # 120
Found function WebF_CON_OpTxPower # 121
Found function WebF_CTL_IFtxMute # 124
Found function WebF_CTL_IFtxDataCW # 125
Found function Web_CON_DivPearl # 127
Found function WebF_PWR_RF_Shutdown # 128
Found function WebF_CTL_Relay1 # 129
Found function WebF_CTL_Relay2 # 130
Found function WebF_CTL_Relay3 # 131
Found function WebF_BB_LoopbackLen # 132
Found function WebF_CON_LoopTrib # 133
Found function WebF_CON_LoopLink # 134
Found function WebF_CON_LoopDis # 135
Found function Web_CON_DivLoopback # 136
Found function Web_FAC_SFPisPresentOrFac # 137
Found function Web_CON_DivRecovery # 138
 14279 bytes
Found function Web_DEB_Level # 140
Found function Web_DEB_WatchdogSw # 141
Found function Web_DEB_WatchdogHw # 142
Found function Web_DEB_Interrupts # 143
Found function Web_DEB_WatchdogSwWho # 144
Found function Web_DEB_DebugData # 145
 2176 bytes
Found function Web_CON_Help_Info # 146
 611 bytes
 4700 bytes
Found function Web_INS_EBLUploadStatus # 148
 617 bytes
Found function Web_CON_Page_FactoryEnter # 149
Found function Web_FAC_Family # 150
Found function Web_FAC_Band_Rates # 151
Found function Web_FAC_PartNo # 152
Found function Web_FAC_ModGen # 153
Found function Web_FAC_ModRel # 154
Found function Web_FAC_SerNo # 155
Found function Web_FAC_MACaddr # 156
Found function Web_FAC_ContHwRev # 159
Found function Web_FAC_IFHwRev # 160
Found function Web_FAC_IFRev # 161
Found function Web_FAC_RFTXHwRev # 162
Found function Web_FAC_RFRXHwRev # 163
Found function Web_MON_WhyStarted # 164
Found function Web_FAC_SFPmodel # 165
Found Variable  OPS_BornOn # 12
 6604 bytes
Found function WebF_FAC_ModNo # 166
Found function WebF_FAC_PartNo # 167
Found function WebF_FAC_SerNo # 168
Found function WebF_FAC_ModGen # 169
Found function WebF_FAC_ModRel # 170
Found function WebF_FAC_MaxPower # 171
Found function WebF_FAC_MinPower # 172
Found function Web_FAC_BandValid # 173
Found function WebF_FAC_Band # 174
Found function WebF_FAC_ContHwRev # 175
Found function WebF_FAC_IFHwRev # 176
Found function WebF_FAC_RFTXHwRev # 177
Found function WebF_FAC_RFRXHwRev # 178
Found function WebF_FAC_TxPower # 179
Found function WebF_FAC_TxPower_Filename # 180
Found function WebF_FAC_RSSI # 182
Found function WebF_FAC_RSSI_Filename # 183
Found function WebF_RF_Tx_TT # 184
Found function WebF_FAC_TempCompPower # 185
 11332 bytes
Found function Web_FEC_FECTest_1 # 186
Found function WebF_FEC_Test1MaxCycles # 187
 2349 bytes
Found function Web_FEC_AllMem # 193
 4353 bytes
Found function WebF_FEC_Usage # 194
 1723 bytes
Found function WebF_FEC_BigBlockStats # 195
 628 bytes
Found function Web_FEC_SerialResponse # 196
 677 bytes
Found function Web_FEC_LinkStats # 197
Found function Web_FEC_LastES # 198
 1724 bytes
Found function Web_FEC_ActiveTest_1 # 199
Found function Web_FEC_Test1Value # 200
Found function Web_FEC_Test1Cycles # 201
Found function Web_FEC_ResetTimeManCold # 202
Found function Web_FEC_ResetCounter # 203
Found function Web_FEC_ResetTimeLast # 204
 1959 bytes
Found function WebF_INS_FPGAFilename # 205
Found function Web_INS_FPGAImage # 206
Found function Web_INS_FPGAImage2 # 207
Found Variable  Web_INS_FPGA_Files(fd,0) # 13
Found Variable  Web_INS_FPGA_Files(fd,1) # 14
Found Variable  Web_INS_FPGA_Files(fd,2) # 15
Found Variable  Web_INS_FPGA_Files(fd,3) # 16
 4396 bytes
Found function Web_INS_FPGAUploadStatus # 208
 619 bytes
Found function WebGenericError # 209
 617 bytes
Found function Web_FAC_ModNo2 # 210
 1293 bytes
Found function WebF_HIS_Date1 # 211
Found function WebF_HIS_Date2 # 212
Found function Web_HIS_LogControl # 213
 6411 bytes
 2797 bytes
Found function Web_HIS_dataRSSI # 214
Found function Web_HIS_RngTxCtl # 216
Found function Web_HIS_RngTxPwr # 217
Found function Web_HIS_RngRSSI # 218
 5314 bytes
Found function Web_HIS_dataTemps # 219
 4852 bytes
Found function Web_HIS_TextReport # 220
 1868 bytes
Found Variable  Web_AD7997_Regs(fd,0,1,0) # 17
Found Variable  Web_AD7997_Regs(fd,0,1,1) # 18
Found Variable  Web_AD7997_Regs(fd,1,1,0) # 19
Found Variable  Web_AD7997_Regs(fd,1,1,1) # 20
Found Variable  Web_AD7997_Regs(fd,0,2,0) # 21
Found Variable  Web_AD7997_Regs(fd,0,2,1) # 22
Found Variable  Web_AD7997_Regs(fd,1,2,0) # 23
Found Variable  Web_AD7997_Regs(fd,1,2,1) # 24
Found Variable  Web_AD7997_Regs(fd,0,3,0) # 25
Found Variable  Web_AD7997_Regs(fd,0,3,1) # 26
Found Variable  Web_AD7997_Regs(fd,1,3,0) # 27
Found Variable  Web_AD7997_Regs(fd,1,3,1) # 28
Found Variable  Web_AD7997_Regs(fd,0,4,0) # 29
Found Variable  Web_AD7997_Regs(fd,0,4,1) # 30
Found Variable  Web_AD7997_Regs(fd,1,4,0) # 31
Found Variable  Web_AD7997_Regs(fd,1,4,1) # 32
Found Variable  Web_AD7997_Regs(fd,0,5,0) # 33
Found Variable  Web_AD7997_Regs(fd,0,5,1) # 34
Found Variable  Web_AD7997_Regs(fd,1,5,0) # 35
Found Variable  Web_AD7997_Regs(fd,1,5,1) # 36
Found Variable  Web_AD7997_Regs(fd,0,6,0) # 37
Found Variable  Web_AD7997_Regs(fd,0,6,1) # 38
Found Variable  Web_AD7997_Regs(fd,1,6,0) # 39
Found Variable  Web_AD7997_Regs(fd,1,6,1) # 40
Found Variable  Web_AD7997_Regs(fd,0,7,0) # 41
Found Variable  Web_AD7997_Regs(fd,0,7,1) # 42
Found Variable  Web_AD7997_Regs(fd,1,7,0) # 43
Found Variable  Web_AD7997_Regs(fd,1,7,1) # 44
Found Variable  Web_AD7997_Regs(fd,0,8,0) # 45
Found Variable  Web_AD7997_Regs(fd,0,8,1) # 46
Found Variable  Web_AD7997_Regs(fd,1,8,0) # 47
Found Variable  Web_AD7997_Regs(fd,1,8,1) # 48
Found function Web_BB_MiscHw # 224
 5642 bytes
 1266 bytes
Found function Web_INS_City # 225
Found function Web_INS_State # 226
Found function Web_INS_Location # 227
Found function Web_INS_Equip # 228
Found function Web_INS_Lat # 229
Found function Web_INS_Lon # 230
Found function Web_INS_Cust_Asset # 231
Found function Web_INS_Cust_SerNo # 232
Found function Web_INS_AttachedDevice # 234
Found function Web_INS_CoCity # 236
Found function Web_INS_CoState # 237
Found function Web_INS_CoLocation # 238
Found function Web_INS_CoEquip # 239
Found function Web_INS_CoLat # 240
Found function Web_INS_CoLon # 241
Found function Web_INS_CoCust_Asset # 242
Found function Web_INS_CoCust_SerNo # 243
Found function Web_CON_Page_BERT # 244
Found function Web_CON_Page_InstallEnter # 245
Found function Web_CON_Page_RSSI # 246
Found function Web_CON_Page_SoftwareUpdate # 247
Found function Web_CON_Page_FPGAUpdate # 248
 9377 bytes
Found function WebF_INS_CLLI # 249
Found function WebF_INS_City # 250
Found function WebF_INS_State # 251
Found function WebF_INS_Location # 252
Found function WebF_INS_Equip # 253
Found function WebF_INS_Lat # 254
Found function WebF_INS_Lon # 255
Found function WebF_INS_Cust_Asset # 256
Found function WebF_INS_Cust_SerNo # 257
Found function WebF_INS_AttachedDevice # 258
Found function WebF_INS_CoCLLI # 259
Found function WebF_INS_CoCity # 260
Found function WebF_INS_CoState # 261
Found function WebF_INS_CoLocation # 262
Found function WebF_INS_CoEquip # 263
Found function WebF_INS_CoLat # 264
Found function WebF_INS_CoLon # 265
Found function WebF_INS_CoCust_Asset # 266
Found function WebF_INS_CoCust_SerNo # 267
Found function Web_CFG_SNMPparams # 268
Found function WebF_SNMP_ReadComm # 269
Found function WebF_SNMP_WriteComm # 270
Found function WebF_SNMP_TrapRcvr # 271
 5513 bytes
 1160 bytes
Found function Web_BB_Loopback # 273
Found function Web_CTL_PwrCtlSource # 274
Found function Web_FEC_BER # 275
Found function Web_IF_RSSI1_engr2 # 276
Found Variable  Web_SYS_Temps(fd,eTEMP_BB) # 49
Found Variable  Web_SYS_Temps(fd,eTEMP_SFP) # 50
Found Variable  Web_SYS_Temps(fd,eTEMP_RF) # 51
Found Variable  Web_SYS_Temps(fd,eTEMP_IF) # 52
Found Variable  Web_SYS_Temps(fd,eTEMP_PWR1) # 53
Found function Web_PWR_Present # 278
Found Variable  Web_SYS_Voltages(fd,ePWR_MonNeg48V) # 54
Found Variable  Web_SYS_Voltages(fd,ePWR_MonNeg5V) # 55
Found Variable  Web_SYS_Voltages(fd,ePWR_Mon1p0V) # 56
Found Variable  Web_SYS_Voltages(fd,ePWR_Mon3p3V) # 57
Found Variable  Web_SYS_Voltages(fd,ePWR_Mon6p0V) # 58
Found Variable  Web_SYS_Voltages(fd,ePWR_Mon12V) # 59
Found Variable  Web_SYS_Voltages(fd,ePWR_Mon5p0V) # 60
Found Variable  Web_SYS_Voltages(fd,ePWR_Mon2p5V) # 61
Found Variable  Web_SYS_Voltages(fd,ePWR_Mon1p2V) # 62
Found Variable  Web_SYS_Voltages(fd,ePWR_MonPoENeg48V) # 63
Found function Web_IF_TxModemLock # 279
Found function Web_IF_Tx_Mute # 280
Found function Web_IF_TxDataCW # 281
Found function Web_IF_TxPowerCtl # 282
Found function Web_RF_SerialIntf # 283
Found function Web_LO_LockDetect # 284
Found function Web_BB_GBICPres # 285
Found function Web_BB_GBIC_LOS # 286
Found function Web_PIC_GBIC_TxPwr # 287
Found function Web_PIC_GBIC_RxPwr # 288
Found function Web_FEC_TxStatus # 289
Found function Web_FEC_RxStatus # 290
Found Variable  Web_EXT_Panel_Relay(fd,1) # 64
Found Variable  Web_EXT_Panel_Relay(fd,2) # 65
Found Variable  Web_EXT_Panel_Relay(fd,3) # 66
Found Variable  Web_EXT_Panel_InName(fd,1) # 67
Found Variable  Web_EXT_Panel_In(fd,1) # 68
Found Variable  Web_EXT_Panel_InName(fd,2) # 69
Found Variable  Web_EXT_Panel_In(fd,2) # 70
Found Variable  Web_EXT_Panel_InName(fd,3) # 71
Found Variable  Web_EXT_Panel_In(fd,3) # 72
Found Variable  Web_EXT_Panel_InName(fd,4) # 73
Found Variable  Web_EXT_Panel_In(fd,4) # 74
Found function Web_MON_OOB_Data # 291
 13257 bytes
Found function Web_CON_WriteAccess # 292
 710 bytes
Found function Web_MON_SysStatus_IMG # 293
Found function Web_Remote_Status_IMG # 294
Found function Web_Remote_Status # 295
Found function Web_BB_TRIBUTARY_IMG # 296
Found function Web_BB_TRIBUTARY_INPUT # 297
Found function Web_Remote_Tributary_IMG # 298
Found function Web_Remote_Tributary # 299
Found function Web_RF_PowerLevel_IMG # 300
Found function Web_Remote_Power_IMG # 302
Found function Web_Remote_Power # 303
Found function Web_IF_RSSI1_IMG # 304
Found function Web_Remote_RSSI_IMG # 305
Found function Web_Remote_RSSI # 306
Found function Web_FEC_BER_IMG # 307
Found function Web_FEC_BER2 # 308
Found function Web_Remote_BER_IMG # 309
Found function Web_Remote_BER # 310
Found function Web_OPS_CoBand # 311
Found function Web_Remote_IPaddr # 312
Found function Web_Remote_UpTime # 313
Found function WebF_OPS_Alarms # 314
 7520 bytes
Found function Web_OTAM_statout # 316
Found function Web_OTAM_statin # 317
 1580 bytes
 2932 bytes
 1666 bytes
Found function Web_FAC_RFxcvr_Data # 318
 396 bytes
Found function Web_FAC_SFPdetails # 319
Found function Web_FAC_SFPdetails_T # 320
Found function Web_FAC_SFPdetails_X # 321
Found function Web_FAC_SFPallRegs_T # 322
Found function Web_FAC_SFPallRegs_X # 323
 4033 bytes
Found function Web_OPS_Title_Short # 324
Found function Web_OPS_StatusLitesStatus # 325
Found function Web_OPS_StatusLites # 326
 2912 bytes
Found function Web_CON_AuthLevel_js # 327
 681 bytes
 645 bytes
Found function Web_INS_TftpXferStatus # 328
 619 bytes
 602 bytes
Found function Web_RF_PowerLevel2 # 329
 605 bytes
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -ohtmldata.o htmldata.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\ADS7830.o ..\PortingCode\ADS7830.cpp
m68k-elf-g++ PortingCode\webfuncs.o PortingCode\utilfuncs.o PortingCode\timer.o PortingCode\testfuncs.o PortingCode\sysvar.o PortingCode\srec.o PortingCode\sfp.o PortingCode\rtc.o PortingCode\rssi_sm.o PortingCode\rssi.o PortingCode\proxy_sm.o PortingCode\power.o PortingCode\otamHtml.o PortingCode\ntpclient.o PortingCode\minilzo.o PortingCode\main.o PortingCode\ioduOut.o PortingCode\ioduIn.o PortingCode\ioduBuffers.o PortingCode\iodu.o PortingCode\htmldata.o PortingCode\hello.o PortingCode\ftpd.o PortingCode\fpgabl.o PortingCode\formcode.o PortingCode\ebl.o PortingCode\eband-mib.o PortingCode\dheap.o PortingCode\debugPrintf.o PortingCode\atpc_sm.o PortingCode\atpcHtml.o PortingCode\atpc.o PortingCode\StopWatch.o PortingCode\SNMPsetup.o PortingCode\SFPhtml.o PortingCode\S25FL129.o PortingCode\RFinterface.o PortingCode\LMK30xx.o PortingCode\LIS33DE.o PortingCode\FECFPGA.o PortingCode\EBqspi.o PortingCode\DmaSerial.o PortingCode\CRC_CCITT_16.o PortingCode\AT45DB.o PortingCode\AT25320.o PortingCode\ADS7830.o PortingCode\ADF4156.o PortingCode\ADF4107.o PortingCode\AD7997.o PortingCode\AD7414.o htmldata.o -Wl,-Map=LR1000.map -mcpu=5208 -Wl -Wl,-n -TC:\nburn\MOD5270\lib\MOD5270.ld -Wl,-RC:\nburn\MOD5270\lib\sys.ld -Wl,--start-group,C:\nburn\lib\MOD5270.a C:\nburn\lib\NetBurner.a C:\nburn\lib\FatFile.a C:\nburn\lib\rtl8711Library.a -Wl,--end-group -oLR1000.elf
htmldata.o:(.data+0x0): multiple definition of `default_page'
PortingCode\htmldata.o:(.data+0x0): first defined here
htmldata.o:(.rodata+0xa): multiple definition of `n_file_record'
PortingCode\htmldata.o:(.rodata+0xa): first defined here
htmldata.o:(.rodata+0x61a): multiple definition of `file_record'
PortingCode\htmldata.o:(.rodata+0x60c): first defined here
c:/nburn/gcc-m68k/bin/../lib/gcc/m68k-elf/4.2.1/../../../../m68k-elf/bin/ld.exe: Warning: size of symbol `file_record' changed from 1940 in PortingCode\htmldata.o to 1960 in htmldata.o
htmldata.o:(.data+0x4): multiple definition of `html_table'
PortingCode\htmldata.o:(.data+0x4): first defined here
c:/nburn/gcc-m68k/bin/../lib/gcc/m68k-elf/4.2.1/../../../../m68k-elf/bin/ld.exe: LR1000.elf section .bss will not fit in region ram
c:/nburn/gcc-m68k/bin/../lib/gcc/m68k-elf/4.2.1/../../../../m68k-elf/bin/ld.exe: region ram overflowed by 2192056 bytes
Time consumed: 20838  ms.
Posted: Wed Dec 29, 2010 6:50 pm
Did you port a bunch of code written for a different platform, or some other library code? Was all this code written by you for the netburner platform?
What is the rev of your tools? It should be in the nbeclipse title bar
Are you using nbeclipse, or a command line makefile?
Posted: Thu Dec 30, 2010 8:10 am
by kmcclure
The code was ported from a NB command line build, and I am using the internal makefile builder in eclipse, and the code was written before I got to it. The release is 2.4 RC2
Posted: Thu Dec 30, 2010 8:45 am
That is what it looked like. There could be unique build conditions in the command line makefile that you would need to duplicate in the nbeclipse build manager settings (right click project properties). But there are a lot of options and screens, so you would need to speak with the person who wrote your command line makefile to determine what if anything needs to be done. Just modifying options in nbeclipse without knowing exactly what you need will create more problems. The beauty of a command line make is you can add lots of conditions, but the down side is if you are picking up a project you need to know what those conditions are. This may or may not be it, but you need to rule it out.
If there is noting special in the makefile, then you might need to do things piece by piece to see what the problem is - don't import the entire code set, just do a little at a time.
Posted: Thu Dec 30, 2010 11:07 am
TWO THINGS:
1. In general to you and others - when you have a lot of data to post consider using gist.github and posting the link here, it's free, fast and convenient.
2. If you created an NBEclipse project and you imported the Htmldata.cpp file, you need to create a new project and don't import it. Always err on the side of not importing things you aren't sure about. It's easy to add a new file, I'm not sure removing works as cleanly. You might be able to repair the current project, but I find it so fast to create a new project that I've never tested just removing the htmldata.cpp file. Having it in your project is always going to cause you problems with multiple defines, get rid of it.
Re: Multiple Defines errors when linking
Posted: Thu Dec 30, 2010 1:21 pm
by kmcclure
I created a new project and moved the files in without the Htmldata.cpp file.
It looks like a clean build but it is still blowing past memory boundaries
so I am still seeing this error
AD7414.o htmldata.o -Wl,-Map=LR1000A.map -mcpu=5208 -Wl -Wl,-n -TC:\nburn\MOD5270\lib\MOD5270.ld -Wl,-RC:\nburn\MOD5270\lib\sys.ld -Wl,--start-group,C:\nburn\lib\MOD5270.a C:\nburn\lib\NetBurner.a C:\nburn\lib\FatFile.a C:\nburn\lib\rtl8711Library.a C:\nburn\lib\debugLibrary.a -Wl,--end-group -oLR1000A.elf
c:/nburn/gcc-m68k/bin/../lib/gcc/m68k-elf/4.2.1/../../../../m68k-elf/bin/ld.exe: LR1000A.elf section .bss will not fit in region ram
c:/nburn/gcc-m68k/bin/../lib/gcc/m68k-elf/4.2.1/../../../../m68k-elf/bin/ld.exe: region ram overflowed by 1837832 bytes
Time consumed: 29254  ms.
