Processing /AlignBERBarsTop.htm
Found function Web_BB_BER_TopRefresh # 6
Found function Web_FEC_BER_Raw # 7
Found function Web_IF_RSSI1 # 8
Found function Web_BB_BER_Bar # 9
Found function Web_BB_BER_Elapsed # 10
Found function Web_BB_BER_CumBERT # 11
Found function Web_BB_BER_CumNoSync # 12
2002 bytes
Processing /AlignBERpost.htm
Found function Web_CON_AccFactory # 13
Found function WebF_BB_BER_Mode # 14
Found function WebF_BB_BERaction # 15
Found function WebF_BB_BER_Histogram # 16
2221 bytes
Processing /AlignRSSI.htm 525 bytes
Processing /AlignRSSIBars.htm
Found function Web_IF_RSSIaidMin # 17
Found function Web_IF_V_RSSI # 18
Found function Web_IF_RSSIaidMax # 19
Found function Web_IF_RSSI1_BAR # 20
Found function Web_IF_RSSI1_BAR_LOW # 21
Found function Web_IF_RSSI1_BAR_HIGH # 22
1845 bytes
Processing /AlignRSSIpost.htm 691 bytes
Processing /AlreadyFull.htm 624 bytes
Processing /AnalogRegs.htm
Found function Web_FAC_Band # 23
Found function Web_ADF4107_Regs # 24
Found function WebF_ADF4107_Freq # 25
Found Variable Web_ADF4156_Regs(fd,1) # 1
Found Variable WebF_ADF4156_Freq(fd,1) # 2
Found Variable Web_ADF4156_Regs(fd,2) # 3
Found Variable WebF_ADF4156_Freq(fd,2) # 4
Found function Web_CON_InputError4 # 26
Found Variable Web_LMK30xx_Regs(fd,1) # 5
Found Variable Web_LMK30xx_Regs(fd,2) # 6
2948 bytes
Processing /atpc.htm
Found function WebF_ATPC_enabled # 27
Found function WebF_local_antenna # 28
Found function WebF_remote_antenna # 29
Found function WebF_link_distance # 30
Found function WebF_ATPC_local_locus # 31
Found function WebF_ATPC_remote_locus # 32
Found function WebF_FSPL_print # 33
Found function WebF_RSL_print # 34
Found function WebF_locus_txPower # 35
Found function WebF_remote_threshold # 36
7366 bytes
Processing /banner.htm
Found function Web_OPS_BannerRefresh # 37
Found function Web_OPS_Title_Browser # 38
Found function Web_OPS_Logo # 39
Found function Web_OPS_Banner # 40
Found function Web_FAC_ModNo # 41
Found function Web_FAC_SerNo_Wrap # 42
Found function Web_INS_CLLI # 43
Found function Web_ATPC_status # 44
1435 bytes
Processing /BERTreport.htm
Found function Web_OPS_Icon # 45
Found function Web_OPS_OwnIPaddr # 46
Found function Web_BB_BER_Started # 4
Found function Web_CFG_BERTgreenThresh # 47
Found function Web_BB_BER_IntervalReport # 48
3832 bytes
Processing /CER.htm
Found function Web_FEC_CER_Raw # 49
621 bytes
Processing /config.htm
Found function Web_CON_Page_ConfigEnter # 50
Found function Web_CFG_LineRate # 51
Found function Web_CFG_CoData # 52
Found function Web_CFG_Authen # 53
Found function Web_CFG_Language # 54
Found function Web_INS_Gateway # 55
Found function Web_INS_CoIPaddr # 56
Found function Web_INS_CoIPport # 57
Found function Web_INS_TftpIp # 58
Found function Web_CFG_TimeSource # 59
Found function Web_BB_RPS_EnDis # 60
Found function Web_BB_RPS_ThreshNdx # 61
Found Variable BB_RPS_DlyStop # 7
Found Variable BB_RPS_DlyStart # 8
Found function Web_CON_DivPortExp # 62
Found Variable Web_EXT_Panel_RelayName(fd,1) # 9
Found function Web_CFG_AlarmRelay1 # 63
Found Variable Web_EXT_Panel_RelayName(fd,2) # 10
Found function Web_CFG_AlarmRelay2 # 64
Found Variable Web_EXT_Panel_RelayName(fd,3) # 11
Found function Web_CFG_AlarmRelay3 # 65
Found function Web_CFG_RSSIredThresh # 66
Found function Web_CFG_RSSIgreenThresh # 67
Found function Web_CFG_AlarmStatus # 68
Found function Web_CFG_SMTP_IP # 69
Found function Web_CFG_SMTP_User # 70
Found function Web_CFG_AlarmUsers # 71
8524 bytes
Processing /configEnter.htm
Found function WebF_CFG_Authen # 72
Found function Web_CFG_ChangePW # 73
Found function WebF_CFG_RSSIredThresh # 74
Found function WebF_CFG_RSSIgreenThresh # 75
Found function WebF_CFG_RSSIthreshUnits # 76
Found function WebF_CFG_BERTgreenThresh # 77
Found function WebF_BB_RPS_EnDis # 78
Found function WebF_BB_RPS_ThreshNdx # 79
Found function WebF_BB_RPS_DlyStop # 80
Found function WebF_BB_RPS_DlyStart # 81
Found function Web_CON_AccInstall # 82
Found function WebF_IF_TxMute_TimeOut # 83
Found function WebF_IF_TxMute_TimeOutLen # 84
Found function Web_Proxy_Enable # 85
Found function WebF_INS_IPaddr # 86
Found function WebF_INS_IPport # 87
Found function WebF_INS_Gateway # 88
Found function WebF_INS_CoIPaddr # 89
Found function WebF_INS_CoIPport # 90
Found function WebF_INS_TftpIp # 91
Found function WebF_CFG_NtpServer # 92
Found function WebF_CFG_NtpUTC # 93
Found function Web_CON_InputError2 # 94
Found function WebF_CFG_AlarmRelay1 # 95
Found function WebF_CFG_AlarmRelay2 # 96
Found function WebF_CFG_AlarmRelay3 # 97
Found function WebF_CFG_AlarmStatus # 98
Found function WebF_CFG_EmailStatus # 99
Found function WebF_CFG_SMTP_IP # 100
Found function WebF_CFG_SMTP_User # 101
Found function WebF_CFG_SMTP_PW # 102
Found function WebF_CFG_SMTP_Sender # 103
Found function WebF_CFG_AlarmUsers # 104
Found function Web_CFG_SMTP_TestResult # 105
13019 bytes
Processing /contents.htm
Found function Web_OPS_Title_Content # 106
Found function Web_CON_Page_OpStatus # 107
Found function Web_CON_Page_FECFPGAStats # 108
Found function Web_CON_Page_Detail # 109
Found function Web_CON_Page_Control # 110
Found function Web_CON_Page_Config # 111
Found function Web_CON_Page_Install # 112
Found function Web_CON_Page_Factory # 113
Found function Web_CON_Page_History # 114
Found function Web_CON_Page_ATPC # 115
Found function Web_CON_Page_Help # 116
Found function Web_CON_Page_Login # 117
Found function Web_OPS_UserIPaddr # 118
Found function Web_FAC_ContRev # 119
4886 bytes
Processing /controlEngr.htm
Found function Web_CTL_PwrCtlSourceFEC # 120
Found function WebF_CON_OpTxPower # 121
Found function Web_FAC_MinPower # 122
Found function Web_FAC_MaxPower # 123
Found function WebF_CTL_IFtxMute # 124
Found function WebF_CTL_IFtxDataCW # 125
Found function Web_CON_InputError1 # 126
Found function Web_CON_DivPearl # 127
Found function WebF_PWR_RF_Shutdown # 128
Found function WebF_CTL_Relay1 # 129
Found function WebF_CTL_Relay2 # 130
Found function WebF_CTL_Relay3 # 131
Found function WebF_BB_LoopbackLen # 132
Found function WebF_CON_LoopTrib # 133
Found function WebF_CON_LoopLink # 134
Found function WebF_CON_LoopDis # 135
Found function Web_CON_DivLoopback # 136
Found function Web_FAC_SFPisPresentOrFac # 137
Found function Web_CON_DivRecovery # 138
14279 bytes
Processing /debug.htm
Found function Web_FAC_ContRevAll # 139
Found function Web_DEB_Level # 140
Found function Web_DEB_WatchdogSw # 141
Found function Web_DEB_WatchdogHw # 142
Found function Web_DEB_Interrupts # 143
Found function Web_DEB_WatchdogSwWho # 144
Found function Web_DEB_DebugData # 145
2176 bytes
Processing /DebugInfo.htm
Found function Web_CON_Help_Info # 146
611 bytes
Processing /eband08.css 1037 bytes
Processing /EBLProgUpload.htm
Found function WebF_INS_TftpFilename # 147
4700 bytes
Processing /EBLUploadStatus.htm
Found function Web_INS_EBLUploadStatus # 148
617 bytes
Processing /factory.htm
Found function Web_CON_Page_FactoryEnter # 149
Found function Web_FAC_Family # 150
Found function Web_FAC_Band_Rates # 151
Found function Web_FAC_PartNo # 152
Found function Web_FAC_ModGen # 153
Found function Web_FAC_ModRel # 154
Found function Web_FAC_SerNo # 155
Found function Web_FAC_MACaddr # 156
Found function Web_FAC_BBHwRev # 157
Found function Web_FEC_FPGASwRev # 158
Found function Web_FAC_ContHwRev # 159
Found function Web_FAC_IFHwRev # 160
Found function Web_FAC_IFRev # 161
Found function Web_FAC_RFTXHwRev # 162
Found function Web_FAC_RFRXHwRev # 163
Found function Web_MON_WhyStarted # 164
Found function Web_FAC_SFPmodel # 165
Found Variable OPS_BornOn # 12
6604 bytes
Processing /factoryEnter.htm
Found function WebF_FAC_ModNo # 166
Found function WebF_FAC_PartNo # 167
Found function WebF_FAC_SerNo # 168
Found function WebF_FAC_ModGen # 169
Found function WebF_FAC_ModRel # 170
Found function WebF_FAC_MaxPower # 171
Found function WebF_FAC_MinPower # 172
Found function Web_FAC_BandValid # 173
Found function WebF_FAC_Band # 174
Found function WebF_FAC_ContHwRev # 175
Found function WebF_FAC_IFHwRev # 176
Found function WebF_FAC_RFTXHwRev # 177
Found function WebF_FAC_RFRXHwRev # 178
Found function WebF_FAC_TxPower # 179
Found function WebF_FAC_TxPower_Filename # 180
Found function Web_CON_InputError3 # 181
Found function WebF_FAC_RSSI # 182
Found function WebF_FAC_RSSI_Filename # 183
Found function WebF_RF_Tx_TT # 184
Found function WebF_FAC_TempCompPower # 185
11332 bytes
Processing /FECFPGA.htm
Found function Web_FEC_FECTest_1 # 186
Found function WebF_FEC_Test1MaxCycles # 187
2349 bytes
Processing /FECFPGAregs.htm
Found function Web_FEC_CntPayloadDrop # 188
Found function Web_FEC_CntLinkDrop # 189
Found function Web_FEC_NoErrors # 190
Found function Web_FEC_CorrErros # 191
Found function Web_FEC_UncorrErros # 192
Found function Web_FEC_AllMem # 193
4353 bytes
Processing /FECFPGAserial.htm
Found function WebF_FEC_Usage # 194
1723 bytes
Processing /FECFPGAserialBigBlock.htm
Found function WebF_FEC_BigBlockStats # 195
628 bytes
Processing /FECFPGAserialResponse.htm
Found function Web_FEC_SerialResponse # 196
677 bytes
Processing /FECFPGAStats.htm
Found function Web_FEC_LinkStats # 197
Found function Web_FEC_LastES # 198
1724 bytes
Processing /FECFPGA_TestResult_1.htm
Found function Web_FEC_ActiveTest_1 # 199
Found function Web_FEC_Test1Value # 200
Found function Web_FEC_Test1Cycles # 201
Found function Web_FEC_ResetTimeManCold # 202
Found function Web_FEC_ResetCounter # 203
Found function Web_FEC_ResetTimeLast # 204
1959 bytes
Processing /FPGAUpload.htm
Found function WebF_INS_FPGAFilename # 205
Found function Web_INS_FPGAImage # 206
Found function Web_INS_FPGAImage2 # 207
Found Variable Web_INS_FPGA_Files(fd,0) # 13
Found Variable Web_INS_FPGA_Files(fd,1) # 14
Found Variable Web_INS_FPGA_Files(fd,2) # 15
Found Variable Web_INS_FPGA_Files(fd,3) # 16
4396 bytes
Processing /FPGAUploadStatus.htm
Found function Web_INS_FPGAUploadStatus # 208
619 bytes
Processing /genericError.htm
Found function WebGenericError # 209
617 bytes
Processing /help_ADC.htm 1491 bytes
Processing /help_EBCC.htm
Found function Web_FAC_ModNo2 # 210
1293 bytes
Processing /HistCont.htm
Found function WebF_HIS_Date1 # 211
Found function WebF_HIS_Date2 # 212
Found function Web_HIS_LogControl # 213
6411 bytes
Processing /histDownload.htm
2797 bytes
Processing /histgraphRSSI.htm
Found function Web_HIS_dataRSSI # 214
Found function Web_HIS_GraphSamples # 215
Found function Web_HIS_RngTxCtl # 216
Found function Web_HIS_RngTxPwr # 217
Found function Web_HIS_RngRSSI # 218
5314 bytes
Processing /histgraphTemps.htm
Found function Web_HIS_dataTemps # 219
4852 bytes
Processing /history.htm 530 bytes
Processing /histtxt.htm
Found function Web_HIS_TextReport # 220
1868 bytes
Processing /HWdevel.htm
Found Variable Web_AD7997_Regs(fd,0,1,0) # 17
Found Variable Web_AD7997_Regs(fd,0,1,1) # 18
Found Variable Web_AD7997_Regs(fd,1,1,0) # 19
Found Variable Web_AD7997_Regs(fd,1,1,1) # 20
Found Variable Web_AD7997_Regs(fd,0,2,0) # 21
Found Variable Web_AD7997_Regs(fd,0,2,1) # 22
Found Variable Web_AD7997_Regs(fd,1,2,0) # 23
Found Variable Web_AD7997_Regs(fd,1,2,1) # 24
Found Variable Web_AD7997_Regs(fd,0,3,0) # 25
Found Variable Web_AD7997_Regs(fd,0,3,1) # 26
Found Variable Web_AD7997_Regs(fd,1,3,0) # 27
Found Variable Web_AD7997_Regs(fd,1,3,1) # 28
Found Variable Web_AD7997_Regs(fd,0,4,0) # 29
Found Variable Web_AD7997_Regs(fd,0,4,1) # 30
Found Variable Web_AD7997_Regs(fd,1,4,0) # 31
Found Variable Web_AD7997_Regs(fd,1,4,1) # 32
Found Variable Web_AD7997_Regs(fd,0,5,0) # 33
Found Variable Web_AD7997_Regs(fd,0,5,1) # 34
Found Variable Web_AD7997_Regs(fd,1,5,0) # 35
Found Variable Web_AD7997_Regs(fd,1,5,1) # 36
Found Variable Web_AD7997_Regs(fd,0,6,0) # 37
Found Variable Web_AD7997_Regs(fd,0,6,1) # 38
Found Variable Web_AD7997_Regs(fd,1,6,0) # 39
Found Variable Web_AD7997_Regs(fd,1,6,1) # 40
Found Variable Web_AD7997_Regs(fd,0,7,0) # 41
Found Variable Web_AD7997_Regs(fd,0,7,1) # 42
Found Variable Web_AD7997_Regs(fd,1,7,0) # 43
Found Variable Web_AD7997_Regs(fd,1,7,1) # 44
Found Variable Web_AD7997_Regs(fd,0,8,0) # 45
Found Variable Web_AD7997_Regs(fd,0,8,1) # 46
Found Variable Web_AD7997_Regs(fd,1,8,0) # 47
Found Variable Web_AD7997_Regs(fd,1,8,1) # 48
Found function Web_ACC_Polarity # 221
Found function Web_ACC_Regs # 222
Found function Web_ACC_Gs # 223
Found function Web_BB_MiscHw # 224
5642 bytes
Processing /images/Alarm.wav 5110 bytes
Processing /images/banner_ADC.jpg 1565 bytes
Processing /images/banner_EBCC.jpg 4365 bytes
Processing /images/bar0.GIF 856 bytes
Processing /images/bar1.GIF 870 bytes
Processing /images/bar10.GIF 856 bytes
Processing /images/bar11.GIF 848 bytes
Processing /images/bar12.GIF 866 bytes
Processing /images/bar13.GIF 856 bytes
Processing /images/bar2.GIF 874 bytes
Processing /images/bar3.GIF 875 bytes
Processing /images/bar4.GIF 876 bytes
Processing /images/bar5.GIF 876 bytes
Processing /images/bar6.GIF 878 bytes
Processing /images/bar7.GIF 875 bytes
Processing /images/bar8.GIF 874 bytes
Processing /images/bar9.GIF 869 bytes
Processing /images/blugrn.gif 1569 bytes
Processing /images/grybmp.gif 1443 bytes
Processing /images/icon_ADC.ico 766 bytes
Processing /images/icon_EBCC.ico 766 bytes
Processing /images/logo_ADC.jpg 893 bytes
Processing /images/logo_EBCC.gif 2367 bytes
Processing /images/radio_off.GIF 853 bytes
Processing /images/radio_on.GIF 861 bytes
Processing /images/StatusGray.GIF 1040 bytes
Processing /images/StatusGreen.GIF 985 bytes
Processing /images/StatusRed.GIF 991 bytes
Processing /images/StatusYellow.GIF 992 bytes
Processing /index.htm
1266 bytes
Processing /install.htm
Found function Web_INS_City # 225
Found function Web_INS_State # 226
Found function Web_INS_Location # 227
Found function Web_INS_Equip # 228
Found function Web_INS_Lat # 229
Found function Web_INS_Lon # 230
Found function Web_INS_Cust_Asset # 231
Found function Web_INS_Cust_SerNo # 232
Found function Web_CON_DivCiena # 233
Found function Web_INS_AttachedDevice # 234
Found function Web_INS_CoCLLI # 235
Found function Web_INS_CoCity # 236
Found function Web_INS_CoState # 237
Found function Web_INS_CoLocation # 238
Found function Web_INS_CoEquip # 239
Found function Web_INS_CoLat # 240
Found function Web_INS_CoLon # 241
Found function Web_INS_CoCust_Asset # 242
Found function Web_INS_CoCust_SerNo # 243
Found function Web_CON_Page_BERT # 244
Found function Web_CON_Page_InstallEnter # 245
Found function Web_CON_Page_RSSI # 246
Found function Web_CON_Page_SoftwareUpdate # 247
Found function Web_CON_Page_FPGAUpdate # 248
9377 bytes
Processing /installEnter.htm
Found function WebF_INS_CLLI # 249
Found function WebF_INS_City # 250
Found function WebF_INS_State # 251
Found function WebF_INS_Location # 252
Found function WebF_INS_Equip # 253
Found function WebF_INS_Lat # 254
Found function WebF_INS_Lon # 255
Found function WebF_INS_Cust_Asset # 256
Found function WebF_INS_Cust_SerNo # 257
Found function WebF_INS_AttachedDevice # 258
Found function WebF_INS_CoCLLI # 259
Found function WebF_INS_CoCity # 260
Found function WebF_INS_CoState # 261
Found function WebF_INS_CoLocation # 262
Found function WebF_INS_CoEquip # 263
Found function WebF_INS_CoLat # 264
Found function WebF_INS_CoLon # 265
Found function WebF_INS_CoCust_Asset # 266
Found function WebF_INS_CoCust_SerNo # 267
Found function Web_CFG_SNMPparams # 268
Found function WebF_SNMP_ReadComm # 269
Found function WebF_SNMP_WriteComm # 270
Found function WebF_SNMP_TrapRcvr # 271
5513 bytes
Processing /jsgraph.js 12994 bytes
Processing /jsgraphReal.js 64334 bytes
Processing /logFail.htm 804 bytes
Processing /manageSettings.htm
1160 bytes
Processing /monitor.htm
Found function Web_MON_SysStatus # 272
Found function Web_BB_Loopback # 273
Found function Web_CTL_PwrCtlSource # 274
Found function Web_FEC_BER # 275
Found function Web_IF_RSSI1_engr2 # 276
Found function Web_MON_UpTime # 277
Found Variable Web_SYS_Temps(fd,eTEMP_BB) # 49
Found Variable Web_SYS_Temps(fd,eTEMP_SFP) # 50
Found Variable Web_SYS_Temps(fd,eTEMP_RF) # 51
Found Variable Web_SYS_Temps(fd,eTEMP_IF) # 52
Found Variable Web_SYS_Temps(fd,eTEMP_PWR1) # 53
Found function Web_PWR_Present # 278
Found Variable Web_SYS_Voltages(fd,ePWR_MonNeg48V) # 54
Found Variable Web_SYS_Voltages(fd,ePWR_MonNeg5V) # 55
Found Variable Web_SYS_Voltages(fd,ePWR_Mon1p0V) # 56
Found Variable Web_SYS_Voltages(fd,ePWR_Mon3p3V) # 57
Found Variable Web_SYS_Voltages(fd,ePWR_Mon6p0V) # 58
Found Variable Web_SYS_Voltages(fd,ePWR_Mon12V) # 59
Found Variable Web_SYS_Voltages(fd,ePWR_Mon5p0V) # 60
Found Variable Web_SYS_Voltages(fd,ePWR_Mon2p5V) # 61
Found Variable Web_SYS_Voltages(fd,ePWR_Mon1p2V) # 62
Found Variable Web_SYS_Voltages(fd,ePWR_MonPoENeg48V) # 63
Found function Web_IF_TxModemLock # 279
Found function Web_IF_Tx_Mute # 280
Found function Web_IF_TxDataCW # 281
Found function Web_IF_TxPowerCtl # 282
Found function Web_RF_SerialIntf # 283
Found function Web_LO_LockDetect # 284
Found function Web_BB_GBICPres # 285
Found function Web_BB_GBIC_LOS # 286
Found function Web_PIC_GBIC_TxPwr # 287
Found function Web_PIC_GBIC_RxPwr # 288
Found function Web_FEC_TxStatus # 289
Found function Web_FEC_RxStatus # 290
Found Variable Web_EXT_Panel_Relay(fd,1) # 64
Found Variable Web_EXT_Panel_Relay(fd,2) # 65
Found Variable Web_EXT_Panel_Relay(fd,3) # 66
Found Variable Web_EXT_Panel_InName(fd,1) # 67
Found Variable Web_EXT_Panel_In(fd,1) # 68
Found Variable Web_EXT_Panel_InName(fd,2) # 69
Found Variable Web_EXT_Panel_In(fd,2) # 70
Found Variable Web_EXT_Panel_InName(fd,3) # 71
Found Variable Web_EXT_Panel_In(fd,3) # 72
Found Variable Web_EXT_Panel_InName(fd,4) # 73
Found Variable Web_EXT_Panel_In(fd,4) # 74
Found function Web_MON_OOB_Data # 291
13257 bytes
Processing /MyHwRegs.htm 5 bytes
Processing /OpenForWrite.htm
Found function Web_CON_WriteAccess # 292
710 bytes
Processing /opstatus.htm
Found function Web_MON_SysStatus_IMG # 293
Found function Web_Remote_Status_IMG # 294
Found function Web_Remote_Status # 295
Found function Web_BB_TRIBUTARY_IMG # 296
Found function Web_BB_TRIBUTARY_INPUT # 297
Found function Web_Remote_Tributary_IMG # 298
Found function Web_Remote_Tributary # 299
Found function Web_RF_PowerLevel_IMG # 300
Found function Web_RF_PowerLevel # 301
Found function Web_Remote_Power_IMG # 302
Found function Web_Remote_Power # 303
Found function Web_IF_RSSI1_IMG # 304
Found function Web_Remote_RSSI_IMG # 305
Found function Web_Remote_RSSI # 306
Found function Web_FEC_BER_IMG # 307
Found function Web_FEC_BER2 # 308
Found function Web_Remote_BER_IMG # 309
Found function Web_Remote_BER # 310
Found function Web_OPS_CoBand # 311
Found function Web_Remote_IPaddr # 312
Found function Web_Remote_UpTime # 313
Found function WebF_OPS_Alarms # 314
Found function Web_OPS_Time # 315
7520 bytes
Processing /otam.css 823 bytes
Processing /otam.htm
Found function Web_OTAM_statout # 316
Found function Web_OTAM_statin # 317
1580 bytes
Processing /OwnRadio.js 1866 bytes
Processing /ProgUpload.htm
2932 bytes
Processing /PWmod.htm
1666 bytes
Processing /RFxcvr.htm
Found function Web_FAC_RFxcvr_Data # 318
396 bytes
Processing /SFPread.htm
Found function Web_FAC_SFPdetails # 319
Found function Web_FAC_SFPdetails_T # 320
Found function Web_FAC_SFPdetails_X # 321
Found function Web_FAC_SFPallRegs_T # 322
Found function Web_FAC_SFPallRegs_X # 323
4033 bytes
Processing /StatusLites.htm
Found function Web_OPS_Title_Short # 324
Found function Web_OPS_StatusLitesStatus # 325
Found function Web_OPS_StatusLites # 326
2912 bytes
Processing /StayAlive.htm
Found function Web_CON_AuthLevel_js # 327
681 bytes
Processing /SysTime.htm
645 bytes
Processing /tbs.htm 590 bytes
Processing /TFTPstatus.htm
Found function Web_INS_TftpXferStatus # 328
619 bytes
Processing /TxPwrCtl.htm
602 bytes
Processing /TxPwrCtl2.htm
Found function Web_RF_PowerLevel2 # 329
605 bytes
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -ohtmldata.o htmldata.cpp
m68k-elf-g++ -O0 -falign-functions=4 -IC:\nburn\include -IC:\PortingCode -IC:\PortingCode\include -IC:\nburn\mod5270\include -IC:\nburn\gcc-m68k\m68k-elf\include -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -include version.def -fno-rtti -fno-exceptions -mcpu=5208 -DMOD5270 -DMCF5270 -oPortingCode\ADS7830.o ..\PortingCode\ADS7830.cpp
m68k-elf-g++ PortingCode\webfuncs.o PortingCode\utilfuncs.o PortingCode\timer.o PortingCode\testfuncs.o PortingCode\sysvar.o PortingCode\srec.o PortingCode\sfp.o PortingCode\rtc.o PortingCode\rssi_sm.o PortingCode\rssi.o PortingCode\proxy_sm.o PortingCode\power.o PortingCode\otamHtml.o PortingCode\ntpclient.o PortingCode\minilzo.o PortingCode\main.o PortingCode\ioduOut.o PortingCode\ioduIn.o PortingCode\ioduBuffers.o PortingCode\iodu.o PortingCode\htmldata.o PortingCode\hello.o PortingCode\ftpd.o PortingCode\fpgabl.o PortingCode\formcode.o PortingCode\ebl.o PortingCode\eband-mib.o PortingCode\dheap.o PortingCode\debugPrintf.o PortingCode\atpc_sm.o PortingCode\atpcHtml.o PortingCode\atpc.o PortingCode\StopWatch.o PortingCode\SNMPsetup.o PortingCode\SFPhtml.o PortingCode\S25FL129.o PortingCode\RFinterface.o PortingCode\LMK30xx.o PortingCode\LIS33DE.o PortingCode\FECFPGA.o PortingCode\EBqspi.o PortingCode\DmaSerial.o PortingCode\CRC_CCITT_16.o PortingCode\AT45DB.o PortingCode\AT25320.o PortingCode\ADS7830.o PortingCode\ADF4156.o PortingCode\ADF4107.o PortingCode\AD7997.o PortingCode\AD7414.o htmldata.o -Wl,-Map=LR1000.map -mcpu=5208 -Wl -Wl,-n -TC:\nburn\MOD5270\lib\MOD5270.ld -Wl,-RC:\nburn\MOD5270\lib\sys.ld -Wl,--start-group,C:\nburn\lib\MOD5270.a C:\nburn\lib\NetBurner.a C:\nburn\lib\FatFile.a C:\nburn\lib\rtl8711Library.a -Wl,--end-group -oLR1000.elf
htmldata.o:(.data+0x0): multiple definition of `default_page'
PortingCode\htmldata.o:(.data+0x0): first defined here
htmldata.o:(.rodata+0xa): multiple definition of `n_file_record'
PortingCode\htmldata.o:(.rodata+0xa): first defined here
htmldata.o:(.rodata+0x61a): multiple definition of `file_record'
PortingCode\htmldata.o:(.rodata+0x60c): first defined here
c:/nburn/gcc-m68k/bin/../lib/gcc/m68k-elf/4.2.1/../../../../m68k-elf/bin/ld.exe: Warning: size of symbol `file_record' changed from 1940 in PortingCode\htmldata.o to 1960 in htmldata.o
htmldata.o:(.data+0x4): multiple definition of `html_table'
PortingCode\htmldata.o:(.data+0x4): first defined here
c:/nburn/gcc-m68k/bin/../lib/gcc/m68k-elf/4.2.1/../../../../m68k-elf/bin/ld.exe: LR1000.elf section .bss will not fit in region ram
c:/nburn/gcc-m68k/bin/../lib/gcc/m68k-elf/4.2.1/../../../../m68k-elf/bin/ld.exe: region ram overflowed by 2192056 bytes
Time consumed: 20838 ms.
