New question on I2C communicationhttp:
bobturner5791
Post by bobturner5791 »
Guys, I got the I2C working I can read my LTC2309 the first time. The next time i run the code it dose not function. Does any one have any thoughts.
Output first time.
Configured IP = 192.168.1.75
Configured Mask = 255.255.255.1
MAC Address= 00:03:f4:04:4f:28
Value of X 0
We have a 0 on the bus
Value of X 1
Value of X 2
Value of X 3
Value of X 4
Value of X 5
Value of X 6
Value of X 7
Value of X 8
We have a 8 on the bus
Value of X 9
Value of X 10
We have a A on the bus
Value of X 11
Value of X 12
Value of X 13
Value of X 14
Value of X 15
Here
Master SX: ,
Receive successfully
Master RX:0, 0,ff, ff
Second Run,
Value of X 0
Value of X 1
Value of X 2
Value of X 3
Value of X 4
Value of X 5
Value of X 6
Value of X 7
Value of X 8
Value of X 9
Value of X 10
Value of X 11
Value of X 12
Value of X 13
Value of X 14
Value of X 15
Here
Failed to read due to error: 4
lly
My Code
#include "predef.h"
#include <autoupdate.h>
#include <dhcpclient.h>
#include <smarttrap.h>
#include <taskmon.h>
#include <NetworkDebug.h>
//#include "i2cmulti.h" //Used for Multi-Master I2C
#include <string.h>
#include "i2cmaster.h"
void UserMain(void * pd);
const char * AppName="lm75";
void UserMain(void * pd) {
StartHTTP();
EnableTaskMonitor();
BYTE buffer[I2C_MAX_BUF_SIZE];
BYTE My_WriteBuffer[I2C_MAX_BUF_SIZE];
/* BYTE address; */
BYTE I2CStat;
BYTE Ascii2Byte( char* buf );
#ifndef _DEBUG
EnableSmartTraps();
#endif
#ifdef _DEBUG
#endif
#ifdef _I2CMASTER_H
I2CInit();
for( int x =0; x<16; x++)
iprintf(" Value of X %d \r\n",x);
if( I2CStart( x, I2C_START_READ ) < I2C_TIMEOUT )
iprintf("We have a %X on the bus\r\n", x );
I2CStop();
iprintf("Here\r\n" );
/*for(int i=0;i < 1;i++){ */
*My_WriteBuffer =0x40;
I2CStat = I2CSendBuf( 8, My_WriteBuffer,1 );
if( I2CStat == I2C_OK )
printf("Master SX: , \r\n");
printf( "Receive successfully\r\n" );
iprintf( "Failed to read due to error: %d\r\n", I2CStat);
I2CStat = ( I2CReadBuf(0x8, buffer, 16));
I2CStop();
printf("Master RX:%x, %x,%x, %x\r\n", buffer[0], buffer[1],buffer[2], buffer[3]);
#endif
// The following function converts the first two ascii chars of a string to a single hex value
v8dave
Re: New question on I2C communicationhttp:
Post by v8dave »
What happens if you power down the board between running the code each time?
Does it then respond each time and only if you do a reset or rerun the programme will it fail?
Just trying to get an idea if this is a hardware issue. A power down will reset all bus devices.
Once thing I do see is that you are trying to read 16 bytes from the I2C device. Is this correct? I am wondering if this is causing the issue of a stuck bus.
bobturner5791
I was not clear on my post, when I first run the code it works as expected. When I run it a second time it does not respond. I can get it to recover when I power down then power back up. The circuit is simple there are two LTC2309 connected to the I2c buss.
Bob
v8dave
Post by v8dave »
Hi Bob,
Looking at the datasheet for the LTC2309, it sends you 16 bits of data as 2 bytes.
your code:
is requesting to receive 16 bytes. Try setting this to 2 and see if this gets it working again. Not sure exactly what the effect of asking the device for more than 2 bytes is but worth a test to see if only asking for 2 works.
The master is expected to NAK after the output of the 2 bytes and because you are requesting 16 it could be confusing it and locking it up.
Cheers,
bturner5791
Post by bturner5791 »
Hi Dave,
I will give that a try. The reason I added the extra bytes was to make sure I was reading the correct data. My results showed that I had received the correct data the first time I read it.
Bob
greengene
Post by greengene »
the only thing that jumps out at me is that it appears you are putting the
device into sleep mode which then requires 200 ms before it will wake up
whenever you next address it. i just did a quick look at the datasheet but
your
appears to be setting the SLP bit.
if you really want to sleep you'll need some logic to work with that.
they show holding off on sending the stop bit and you can do that
with the i2c lib by adding false as the 4th parameter to I2CSendBuf
and then wait your 200 ms and then call I2CStop.
v8dave
Post by v8dave »
Reading more bytes for some devices can lead to lockups. I have seen this in the past.
If you look at your reply, you will see FF, FF as the last 2 bytes indicating no data on the bus (pulled up)
I think Greengene might have spotted the other issue. Try leaving the ADC in normal mode instead of sleep and only request 2 bytes and see if it works then.
bobturner5791
Hi Dave,
First I was reading back single ended so I should have been 0x80 instead of 0x04. I called a friend over at ltx and he put me in touch with the product engineer of the2309 and for sleep mode to function the bit has to be high.
I did not want to set the sleep bit. I did modify the to to write then read back right a way. and the results were intermittent.
Master RX: , 0, 50
Done:
Failed to Read due to error: 9
Done:
55.255.1
#include "predef.h"
#include <string.h>
StartHTTP();
/* BYTE address; */
BYTE I2CStat;
#ifndef _DEBUG
EnableSmartTraps();
#endif
#ifdef _DEBUG
#endif
#ifdef _I2CMASTER_H
I2CInit();
*My_WriteBuffer =0x80;
I2CStop();
I2CStat = ( I2CReadBuf(8, buffer, 2));
printf("Master RX: , %x, %x \r\n", buffer[0],buffer[1]);
iprintf( "Failed to Read due to error: %d\r\n", I2CStat);
I2CStop();
iprintf( " Done: \r\n");
#endif
Then I tried to set the stop to fail an it never passed.
I2CStat = I2CSendBuf( 8, My_WriteBuffer,1 , bool stop = false);
Dave one other question when writing a address like 10, is it 0x10 or 0xa?
thanks
Bob
v8dave
Post by v8dave »
Hi Bob,
Quick question. Do you have pullups on the SDA and SCL lines?
As for the 10 question, it depends on whether it is HEX or DECIMAL. If decimal, 0xA would be correct as would just plain old 10. If HEX the 0x10 would be needed.
By the way, the calll to I2CReadBuf and I2CWriteBuf will do the stop for you if you set the BOOLEAN to true or leave it as default. No need for the extra stop call.
greengene
Post by greengene »
doh! i was reading the command bits bassackards!
maybe it is me that needs the sleep not the device.
