Has anyone here worked with the quadrature input on the eTPU of the MOD5234?
I have a panel mounted rotary encoder that generates 30 pulse per rev and I can see the input pins on the device clocking as I turn the knob.
The issue I have is in setting up and reading the eTPU for QD input.
I use the following to init the eTPU for QD input.
fs_etpu_qd_init(GPIO_ENC_A,
0,
0,
FS_ETPU_QD_PRIM_SEC,
FS_ETPU_PRIORITY_MIDDLE,
0,
FS_ETPU_TCR1,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0);
I then call this function to read the value and it hangs from this point and never returns.
Count = fs_etpu_qd_get_pc(GPIO_ENC_A);
Any ideas what else I need to do to get this to work as there are no examples of using the eTPU or quadrature inputs?
Cheers,
Quadrature input with the eTPU
Re: Quadrature input with the eTPU
OK, been doing some debugging and getting something strange in this function call.
int24_t fs_etpu_qd_get_pc( uint8_t channel_primary)
return(fs_etpu_get_chan_local_24s(channel_primary, FS_ETPU_QD_PC_OFFSET));
The call to fs_etpu_get_chan_local_24s does return, but when this function goes to return it hangs!!
I thought it was a stack issue and increased the size in the task that this call is made to 1024 in size but still same issue.
Need to delve a little more into the stack before and after this call.!!
I can probably help. We created the tools that generated teh frescale libraries.
Walter@bytecraft.com
Send me more details for the question or post them here.
w..
w..
Hi Walter,
I sorted the crash. I made the usual mistake with pointers and passed in the value instead of a pointer to it. Oops.
Still not getting any counts but that might be the configuration. Maybe you can help with this. This is what I have for config. The encoder is 30ppr.
0,
0,
0,
FS_ETPU_TCR1,
0, 0, 0, 0, 0,
0x733333,
0x8CCCCC, 0, 0, 0,
1000,
30);
fs_etpu_qd_set_pc(GPIO_ENC_A, 0);
fs_etpu_qd_disable(GPIO_ENC_A, 0, 0, 0);
fs_etpu_qd_enable(GPIO_ENC_A,
0,
0,
FS_ETPU_PRIORITY_MIDDLE);
fs_etpu_qd_set_slow_mode(GPIO_ENC_A);
GPIO_ENC_A is set to 8 and I am using channels 8 & 9 for the inputs. I can see them toggling with the scope.
Cheers,
0,
0,
0,
FS_ETPU_TCR1,
0, 0, 0, 0, 0,
0x733333,
0x8CCCCC, 0, 0, 0,
1000,
30);
0,
0,
Cheers,
It would appear that the Quadrature decoder is not included with the NNDK set that gets loaded into the eTPU.
There is another set for this but I see that it does not support UART and I need both UART and QD in the same set.!!
Off to do some more digging.
It's working.
I finally figured out that the standard build does not include quadrature as part of the eTPU so I went to the Freescale website and created my own custom eTPU build and now it works!!
Excellent!
Excellent!
