Closing projects
Closing projects
Closing projects in NBEclipse is very annoying. After clicking on "Close" from the menu, the project remains in the main project window. How doeo one remove this without delecting any files? Thanks! Pat
Re: Closing projects
You can set the Project Explorer windows up to hide closed projects. To do this, go tot he project window and click on the down arrow (view menu) and click on Customize View. Check "Closed Projects". Hit apply/ok and the closed projects will be filtered out.
Thanks that worked! Highly recommend you guys make this a "defualt setting switch" in all future versions! Pat
