Problem with SD card init after unexpected CPU reset
Taris
Post by Taris »
I have a problem with SD card after CPU reseting. I'm using an example "nburn\examples\EFFS\EFFS-BASIC" for to find out how to work with SD card.
The program works great if I wait until program starts and only then I insert SD card and press <enter> button. You can see a log below:
===== Starting EFFS BASIC MMC/SD Program =====
No MMC/SD card detected. Insert a card and then press <Enter>
FAT mount to SD/MMC successful
SD/MMC drive change successful
Retrieving external flash usage...
Flash card memory usage (bytes):
32014336 total, 32012288 free, 2048 used, 0 bad
Found File [TESTFILE.TXT] : 75 Bytes
Creating test file: TestFile.txt
Wrote 15 bytes: Hello World 0
Wrote 15 bytes: Hello World 1
Wrote 15 bytes: Hello World 2
Wrote 15 bytes: Hello World 3
Wrote 15 bytes: Hello World 4
Rewinding file
Read 75 bytes:
Hello World 0
Hello World 1
Hello World 2
Hello World 3
Hello World 4
Closing file TestFile.txt
Unmounting SD/MMC card
Program complete. Reset to repeat
After this test I press reset button with inserted SD card and this time the program does not work correctly. You can see the log below:
FAT mount to SD/MMC failed: F_ERR_NOTFORMATTED
*** Error in f_getfreepace(): F_ERR_NOTFORMATTED
*** Error opening file "TestFile.txt", fp = 0
Why does not the program work correctly after reset with iserted SD card second time?
I would like write a program which will initialize a SD (with FAT) card properly after unexpected CPU reseting. Now I need remove SD card after first unexpected CPU reseting then insert and initialize.
Best regards
Re: Problem with SD card init after unexpected CPU reset
What happens if you format the sd card to fat 32 on your pc, then repeat that test?
Can you see the files if, after just the first part where it appears to work correctly, you then put it in your pc and view the files. Are they intact?
Taris
Post by Taris »
rnixon wrote:What happens if you format the sd card to fat 32 on your pc, then repeat that test?
I made a mistake I'm using not SD card but MMC card!!! It is SanDisk MMC 32MB card. I can't format this card to FAT32
I can see files with my pc. There is no problem with card. Yes I know that this card is very old :) , but it was first card which I found at home :). I will try to find new module card and I will repeat the test...
Taris
Post by Taris »
I made this test (I wrote in my first post) with Kingston 2GB SD card and the test program worked great after second CPU reset. I don't understand why are the testing results is different with Sandisk MMC 32MB :) and Kingston 2GB SD...???? Do EFFS Function calls support old MMC card? Does somebody know about this issue? There is no guarantee that customers won't insert old 32MB MMC card...
What is a program skeleton which have possibility to reinitialize SD (with FAT) after unexpected CPU reset?
