speed.exe from TCP Speed Test example crashes
In trying to run the speed test example, the PC executable crashes. I get the Windows "speed.exe has encountered a problem and needs to close. We are sorry for the inconvenience" dialog when I attempt to run it. I am running XP SP3.
Re: speed.exe from TCP Speed Test example crashes
I just tried in on vista with the latest updates, and it works. The type of network interface you are using may make a difference. I a running on a std. PC with a network card. What type of system do you have? Does it have multiple network interfaces, wifi only, etc.
I am running it on a laptop with built in wifi. The netburner is connected direct to the pc. I have also tried it on another desktop pc running xp with the same result.
