Factory state of Netburner (MODXXXX) products
AlokD
Post by AlokD »
I’m wondering what is the factory state of the MODXXXX line of products.
Is there an HTTP server that is part of the of the pre-flashed .s19 application? Can I detect the board IP address using IPSetup when it is in its factory state and reprogram it using AutoUpdate (once I am on the same network as its IP address)?
The reason I ask is because I have received a new product (MOD54415) and am having some difficulty communicating with it over RS-232 for reprogramming. If it can communicate over IP from the start, that would be preferable so I can figure out the serial while I start to use it.
If there's some info about that which I missed, please let me know.
AlokD
Re: Factory state of Netburner (MODXXXX) products
Post by AlokD »
This can be closed. Discovered later that a factory application (with AutoUpdate built-in) is indeed running on the products out-of-the-box.
Thanks for letting us know AlokD. One more note since the MOD5441X and NANO54415 products can run both 2.x and 3.x tool sets: because those platforms came out prior to 3.x, all units ship with a 2.x factory application so people in situations like yours are not affected. For those using 3.x, once you upload a 3.x application, the device will stay in 3.x mode.
