Setting Timezone Seems Broken
ecasey
Post by ecasey »
I am trying to migrate from 2.8.6/7 to 2.9.5 on a MOD5282. Setting the Timezone doesn't work anymore. This code
putenv("TZ=EST5EDT,M3.2.0/2,M11.1.0/2");
Now_t = time(NULL);
localtime_r(&Now_t,&Now_tm);
localtime(&Now_t);
cout << "Timezone: " << getenv("TZ") << endl;
cout << "Time: "<< put_time(localtime(&Now_t), "%c %Z") << endl;
has always worked, but in 2.9.5 it refuses to set the timezone to EST. Here is the output:
    Timezone: EST5EDT,M3.2.0/2,M11.1.0/2
    Time: Sat Jun 18 12:16:07 2022 GMT
I output the "Timezone ..." twice to show that nothing changed by calling localtime() inside the stream.
The revision notes show a change in time_t to a 64-bit value, but nothing about Timezones.
Did I miss something or is this a bug?
Ed
Re: Setting Timezone Seems Broken
I'm not an expert in the time zone area, but I'll give it try until someone else can join in. Most OS's have a tzset() function. In 2.9.x we have a tzsetchar() function. For example, tzsetchar((char*)"EST5EDT4,M3.2.0/01:00:00,M11.1.0/02:00:00"); for eastern time. There are two examples that might help:
1. \nburn\examples\StandardStack\EFFS\EFFS-HTTP\main.cpp
Shows how to set it as described above
2. \nburn\examples\StandardStack\NTPClient\main.cpp
Uses the timezones.h header file which provides all the time zones in an array you can use. Note that the actual time zone strings are in \nburn\system\timezones.cpp.
Let me know if that helps
ecasey
Post by ecasey »
Well, tzsetchar((char*)"EST5EDT4,M3.2.0/01:00:00,M11.1.0/02:00:00") worked. I never thought to try it. I was expecting the putenv() method to continue to work. I guess it was the move to GCC 8.1 that killed it. All's good with Timezones now; just have to make the switch to tzset() in all my applications.
Thanks Tom!
Ed
Wow I never realized that the putenv ever work.
I learned something.
