How to derive a class from DSPI
jpelletier
Post by jpelletier »
I want to do a display based on the DPSI driver. It is a class that inherits from DSPI. How should I do this exactly?
In display.h:
In display.cpp:
class Display : public DSPIModule
    public:
        Display();
        virtual ~Display();
etc.
Display::Display()
    m_Module = DEFAULT_DSPI_MODULE;
    /* Initialize pins needed for DSPI */
    /* definitions snipped */
    // Initialize DSPI with baudrate of 1 MHz, 8bit mode, inactive on all CS is High, assert CS1 Low
    //FIXME how to setup SPIModule?
    DSPIModule SPIFlashIC(DEFAULT_DSPI_MODULE, 1000000, 8, CHIP_SELECT_0, CS_ASSERT_LOW);
Re: How to derive a class from DSPI
I would make the DSPI a member variable, not derive the class...
If you do want to derive the class then that is nto the correct syntax for the base class constructor...
Take a look here:
https://en.cppreference.com/w/cpp/language/constructor
jpelletier
Thanks! That will help.
