Json reader
fredy-gutierrez
Json reader
Post by fredy-gutierrez »
Hi everyone,
I´m working with the json lexer, I was trying to print a post result in json which has a json object in main json object, so I want to print the data of the second json object, I was reading the documentation of json_lexer class and I found this method, FindFullName("obj1.obj2Element") but It return a json_primative_type data so I can´t print it like a string, I tried to print the object using printf("Object [%s] \r\n", JsonInObject.FindFullNameString("obj1.obj2Element")) but It return null, some one know how can I print the result, I will appreciate any help provided
Thanks Fredy
Json example
"SUCCESS": true,
"obj1": {
"obj2Element": "value 01",
"obj2Element2": "value 02"
Re: Json reader
The Lason lexer has member function to do that...
Is this a 2.X or 3.X NNDK (they are very slightly differnt)
Basic outline:
You have a ParsedJsonDataSet pjds;
it has an internal positions...
so
json_primative_type jtype=pjds.FindFullName("obj1.obj2Element");
//Returns the type of object at that location and changes pjds to have the current pointer pointed there...
//So
printf("We found a %s\r\n",GetTypeName(jtype));
switch (jtype)
case NOTFOUND: printf ("Not found\r\n"); break;
case STRING: printf("String :%s\r\n",pjds.CurrentString()); break;
case NUMBER: printF("Number %g\r\n", CurrentNumber()); break;
etc....
You can call: pdjs.ResetPosition();
To reset the data set to the begning...
Also:
//Print to stdio
void PrintObject(bool pretty=false);
//Print to a char buffer, returns chars written
int PrintObjectToBuffer(char * buffer, int maxlen,bool pretty=false);
//print to an FD
void PrintObjectToFd(int fd,bool pretty=false);
Re: Json reader
If your working in 3.X then then explain more of what your doing and we might have some big short cuts using the config system,,, to reduce your workload..
fredy-gutierrez
Re: Json reader
Hi, hanks a lot, I will try to do it, thanks for your answer
Re: Json reader
Let me know if that fixes things for you.
