how to generate a delay of 1 msec using GPTA/GPTB?
savaliya_ambani
Post by savaliya_ambani »
hi,
i have one issue regarding the GPTA/GPTB(i am using as a timer).
i want to generate a delay of 1 msec using any one channel of the general purpose timers,lets say GPTA/CH0. for this i have configured all the registers and also written ISR for this to do the my stuff.
SetIntC(0,&MY_ISR,44,1,1) // THIS IS FUNCTION (any thing wrong in this??)
now, i have load the count in the register sim.gpt[0].c0=0x0fff; than even if i change this count to any value, i got the same time delay.i.e there is no change in delay w.r.t channel counter.
can i use the channel 0 of GPTA as a timer? if yes how can i?
I got my TIme delay using the PIT, but i want to use the GPTAin my application. can any body help me out, if possible some sort of code will help me much.
thanks to all of you.
thomastaranowski
Re: how to generate a delay of 1 msec using GPTA/GPTB?
Post by thomastaranowski »
You didn't list the platform you're using, but if I recall correctly, the first general purpose timer(GPTA/CH0) is used for the OS timer
savaliya_ambani
ohh sorry for that.
I am using the MOD5282,ColdfFIre platform.
And I am using the GPTA/CH0, which is you mentioned used by the OS. So, i will try on ch1. But one thing i want the list of the registers required to configure for the delay of 1mSec.
I Think by changing the Channel register count will provide me the variable delay.
Thank you.
