We have found two significant issues in 2.8.
One in the ethernet Driver for all 5441X parts, and one in TCP that effects all devices.
We will be putting together 2.8.1 some time in the next week... expect a release in about a week.
We should also do a 2.7.6 a few days after that.
Version 2.8 issues..
Re: Version 2.8 issues..
One more thing to look at:
in 2.8.0 ostringstream is having trouble with floats and doubles.
This code:
outputs:
If I comment out the setiosflags(std::ios::fixed), the "f" becomes a "g".
Insights?
This code:
ostringstream JSON;
string Cvalue = "(=)";
string Text = "Wind Direction";
int Precision = 2;
string UOM = " MPH";
float Value = 7.212;
while (1) {
JSON.str("");
JSON << "{\"SENSOR\" : \""
<< Text
<< "\"VALUE\" : \""
<< Cvalue
<< setiosflags(std::ios::fixed)
<< setprecision(Precision)
<< Value
<< UOM
iprintf("\n%s\n",JSON.str().c_str());
OSTimeDly(TICKS_PER_SECOND*20);
}Note the "f" where the "7.21" should be. It does this for doubles and floats. Ints are handled correctly.{"SENSOR" : "Wind Direction","VALUE" : "(=)f MPH"}
Insights?
Uh... Right. This is weird. Thanks for the heads up.
Looks like this is probably an issue with the C++ STL. Not sure whether it's a bug in the version we used or a miscompilation.
We have a fix for the stream stuff... ask on support....
Should have a 2.8.1 beta early next week..
