I'm a newb so I apologize for stupid questions but, can I do a functioncall from .htm files loaded on an SD card?
I could get the functioncall to work on the index.htm file that is called when no card is installed but not off the index.htm that I put on the SD card.
EFFS-HTTP Functioncall
Re: EFFS-HTTP Functioncall
I think FUNCTIONCALL only works with code compiled in the application. Other than compile time, there is no way to link the functions.
rnixon is correct. You might want to look at using an Ajax approach (http://www.netburner.com/support/techni ... eb_content) to do the required updates. You will still need a stub .htm file that gets compiled into your application, though.
Thanks for the replies.
Will I be able to take data off the SD card and process it into my compiled .htm file (ie display a data log)?
OK so I just found my answer(s) in the EFFS programmers guide. There is a lot of info to work through! I didn't know that guide was there. Sorry.
