				MOD54415 Task Monitor SizeLeft = ?
				Posted: Thu Jan 01, 2015 10:05 am
				by jediengineer
				I loaded my firmware into a unit, and had a few bugs but I can't figure out one of them. When my unit loads, it initializes the GPIO being used as just IO, Then a DAC, which loads fine, then a SPI controlled ADC. This worked perfectly in my last version of my software so I never touched the code, but right after my DSPIInit function, as it begins to send a dummy read command to the ADC (mfgr spec) the task monitor (I believe) splashes the screen with "SizeLeft: 0" or "SizeLeft: 2" - not sure what this means - Screenshot attached. I should note that I originally had code that loaded values from user flash prior to loading the peripherals. I have since removed this line of code. I also attached a few screenshots of the code, sorry, not allowed to show any more of it... And sorry if it's squashed a little, had to cut out a few comments to get it all on the page.
So, can someone enlighten me on this? Thanks for all the help!!!
				Re: MOD54415 Task Monitor SizeLeft = ?
				Posted: Sat Jan 03, 2015 11:45 am
				by ecasey
				It is unlikely that the "SizeLeft" output is coming from TaskMonitor; that code is only invoked by the TaskScan utility when you run it from the NBEclipse IDE.
It is more likely that there is a printf() statement somewhere in your code that is outputting "SizeLeft".  You should do a file search for that statement.
I see that you are running NBEclipse Release 2.6.9 which was unstable and pulled by the NB development team.  As a first step, I would try rolling back to 2.6.8  or  2.6.7 .If it works in those releases then you might try 2.7.0, although that is a beta release.
Ed
				Posted: Sun Jan 04, 2015 4:17 am
				by jediengineer
				Thanks Ed,
I'm don't fully understand TaskScan enough to understand how to interpret what I see.  I can tell you this though,  this is occurring in one of my startup functions.  This function hasn't changed since Rev3 of my software and has always worked.  I only just recently added iprintf statements when I noticed that my system was locking up at startup. I sometimes do that in lieu of running the debugger so that I don't have to disable any of my timers or the cwt (Still learning a bit...). None the less,  my iprintf statements end before the main while loop. None of my iprintf statements are outputting "SizeLeft". This output is occurring in a loop that has no iprintf statement. It is the 16 count loop under the "ADC_Setup()" function.
This is the loop:
			for (int i = 0; i < 16; i++)
				DSPIStart(3, TXBuff, RXBuff, 2, NULL, true);
				while(!DSPIdone(3));
				receive[i] = ((RXBuff[0] << 8) | RXBuff[1]);
Also, I did not run the debugger if that's what you're referring to. I'll try loading it through "AutoUpdate" to see if that makes a difference.
 2.6.9 was pulled? I Was unaware.  I was told it was released to fix the SPI bug (among a few others) from 2.6.8. This code ran perfectly on 2.6.5, I will attempt 2.7.0.
				Posted: Mon Jan 05, 2015 5:22 am
				by jediengineer
				Hey Ed and everyone else that has read this post:
Ed was right, NNDK 2.6.9 was the issue. I rolled back to 2.6.7 to be safe, and all the problems went away - everything is working as designed. Thanks for the info, Ed!
				Posted: Mon Jan 05, 2015 5:54 am
				by sulliwk06
				it looks like there are a couple of iprintf statements that got left in dspi.cpp at some point. I commented them out in mine and rebuilt system files, no more problem.
				Posted: Mon Jan 05, 2015 11:07 am
				by jediengineer
				That wasn't my only issue - it would freeze up at random points too and I'd get the TaskScan message in MTTTY just before it would reboot itself. But the freeze point became a bit sporatic - so it never froze in the same place all the time...
