EthenetIP
roland.ames
EthenetIP
Post by roland.ames »
I have been using this 'variable' to tell me what IP address the netburner module is accessible on. If EthernetIP == 0, there is no ethernet available, otherwise it is equal to the IP address. This was all working fine until AutoIP was introduced, now I find that if the IP address being used is generated by the AutoIP function, EthernetIP remains at zero.
Is there a simple way to find which IP address is being used, regardless of whether it is static, DHCP'd or AutoIP'd, I just want some function that will return the IP address being used (as it appears in IPSetup or AutoUpdate)
this is my initialisation, I do not time out on getting DHCP'd on powerup, I want to handle situation where the ethernet is not necessarily connected at powerup, but should be able to be connected / disconnected to either a network (DHCP) or a laptop (AutoIP) at any time
    if (EthernetIP == 0)
        DhcpObject * pDhcpObj = new DhcpObject();
        pDhcpObj->StartDHCP();
    OSChangePrio(MY_MAIN_PRIO);
    EnableSmartTraps();
    EnableTaskMonitor();
I have come up with a function that I think will do what I want
IPADDR GetCurrentIP(void)
	// search through interface blocks in sequence until a non-zero IP is found, return the non-zero IP, or return 0 if cannot find any non-zero IP
	IPADDR ip=0;
	int i=0;
	while( !ip && (i=GetnextInterface(i)) )		// GetFirstInterface() is the same as GetnextInterface(0)
		ip = InterfaceIP(i);
	return ip;
this is not intended to be useful in all systems, my system has just the single ethernet connection, but the ip address could be static, dhcp or autoip. I will be testing soon.
sulliwk06
Re: EthenetIP
Post by sulliwk06 »
I actually use multihome addressing so I can use both DHCP and static addresses. This is how I look at all of my IP addresses:
   numInterfaces = AddInterface( AsciiToIp( Cur_Settings.staticIP ), AsciiToIp( Cur_Settings.staticMask ), 0 );
   iprintf("\r\nTotal number of interface addresses: %d\r\n\r\n",numInterfaces);
   int lastInterface;
   for(int i = 0; i < numInterfaces; i++)
	   int thisInterface;
	   if(i == 0)
		   thisInterface = GetFirstInterface();
		   thisInterface = GetnextInterface(lastInterface);
	   lastInterface = thisInterface;
	   iprintf("---------------------------\r\nAddress #%d\r\n",i+1);
	   InterfaceBlock *thisIb;
	   thisIb = GetInterFaceBlock( thisInterface ); // Get interface data
	   iprintf( "IP Address: " ); ShowIP( thisIb->netIP ); iprintf( "\r\n" );
	   iprintf( "Mask      : "); ShowIP(thisIb->netIpMask);iprintf("\r\n");
roland.ames
Re: EthenetIP
I am not familiar with the multi-home features. I am using just the single physical interface, no wifi or ethernet2.
I wanted a function that return the ip address as it appears in the IPSetup window.
I have tested the following code and it works for me, but I have not even considered the situation with wifi or a second LAN
char IPMode;
	InterfaceBlock * ifp = GetInterFaceBlock();
	if (ifp->dhcpClient)
		if ( ifp->dhcpClient->ValidDhcpLease() )
			IPMode = 'D';							// for debugging indicates DHCP
			return ifp->dhcpClient->DhcpClientIP;
		InterfaceBlock * cifp = ifp->pChild;
		if ( (cifp) && (cifp->AutoIPC) && (cifp->AutoIPC->getState() == AUTO_IP_CONFIGURED) )
			IPMode = 'A';							// for debugging indicates AUTOIP
			return cifp->netIP;
		IPMode = 'S';								// for debugging indicates STATIC
		return ifp->netIP;
	IPMode = 'N';									// for debugging indicates NO VALID IP
	return 0;
