I am very new at this and need some advise or help. I have setup the IP to the netburner SBL2E and can ping and view the web browser. Although I am about to browse via IP, I am not able to telnet into the device no matter what I try. I have tried telnet using 23, 24, 1000, 1001 but no luck. I cannot seem to find what I need to log into the device via telnet no matter what I read online. Maybe I'm missing something?
commands I've tried:
telnet 1.1.1.1 23
telnet 1.1.1.1 24
telnet 1.1.1.1 1000
telnet 1.1.1.1 1001
telnet not connecting - bad pin number?
Re: telnet not connecting - bad pin number?
What code is the SBL2E running?
If its runnign the factory tcp to serial app, did you configure the tcp to serial(using a web browser)
so that t was accepting tcp/telnet connections ?
Hey thank pbreed for the reply. I think something is wrong with the OS because I was waiting on a Welcome prompt. I believe it did connect because I would press the letter v and it would give me the version number of the board.
Now the question is why or what do I do next to get the default or demo OS on the device to run eclipse on it and write some code. I really just want to grab all the data in the RAM and pull it off through telnet or tftp. Can you help?
the V version would be the monitor via a serial port, not the telnet.
There is no telnet command server just a telnet to serial gateway...
Did you buy a bare SBL2E or a dev kit with tools?
If a dev-kit with tools follow the getting started guide... exactly...
Otherwise submit a support request.
support.netburner.com
