Digi WiFi embedded modules: Wi-9C, Wi-ME, Wi-EM. Has anyone tried attaching these to NetBurner products?
Chris Ruff
Digi WiFi modules..Has anyone tried to use one of these?
- Chris Ruff
- Chris Ruff
Re: MultiTech or ConnectOne..used one of these WiFi ?
How about Multi-Tech or Connect-One
Anybody using these?
Re: Digi WiFi modules..Has anyone tried to use one of these?
Hi Chris,
No, actually I'm not using them. But I have an Arduino BT. It uses the Bluegiga WT11.That is a very good (one of the best) device.
Regards,
sb70koll
Regards,
sb70koll
Kind regards, sb70koll
Simplicity is my middle name - Danny Glover - Predator II
- Chris Ruff
OK, I see all of these (WT11) parts, but how do you map these bluetooth devices to WiFi? Am I missing something?
No Chris, I'm missing something
Forgive me, I tangled up bluethooth with WIFI.
- Chris Ruff
I am presently looking at the Quatech Airborne modules. The 802.11 b/g module is $44 dollars and looks very interesting. Does anyone know of any reason why that module would be a bad choice for a 5270 environment?
Hi Chris,
Looked at some of their modules but could not find the $44 type. I read the WLNG-AN-DP101 sheet and saw that these devices need 3.3V supply so you might need to do some level shifting and/or need a second power supply (dc/dc) if the Netburner is powered with 5V.
sb70koll
sb70koll
- Chris Ruff
Digi is $85
QUATECH Airborne is $44
