Printf and multiple threads
andystephenson
Post by andystephenson »
I have read somewhere, but I can't find it now, that if you are using printf from multiple threads, you can't use buffered comms - or something to this effect.
Can someone point me to the doc that discusses this, as I want to see what exactly you have to do. When experimenting earlier, I used a critical section around my debug call to make it work, but I may have got lucky.
Do I need to post on yahoo as well, or are most people keeping an eye on both groups?
Andy
Re: Printf and multiple threads
In some versions of the system Floating Point printf from multiple threads caused some problems.
I believe that this is resolved in the latest releases.
iprintf has always been safe (iprintf is printf without floating point, a lot smaller in the library)
It is possible that printf from multiple threads can cause output wierdness
For example task 1 is printing "The Quick brown fox jumped over the lazy dog"
and task 2 a higher priority gets woken up and prints "at the tone the time is 12:45"
What might come out the serial port is
"The Quick brown fox jat the tone the time is 12:45umped over the lazy dog"
If you need the printf's to be complete by task then you need add some protection to make sure this does not happen.
