Mod5270 - mode of execution after loading from bootloader
sreenath
Post by sreenath »
Hi
This is the first time I am using Mod5270. If I load a program into Mod5270 RAM/Flash, will it be run in user mode or supervisor mode? Specifically, does the boot-loader (the monitor) switch over to user mode before handling control to user program, or continue in supervisor mode? I will use the serial port to load user programs to mod5270.
Also, has anyone used Freebsd to communicate with Mod5270? I have GCC compiler for 68k/coldifire setup on my freebsd desktop, and would like to load programs to 5270 from this system.
thanks,
Sreenath
Re: Mod5270 - mode of execution after loading from bootloade
You are always in supervisor mode, no switch is made at boot time.
sreenath
Post by sreenath »
-Sreenath
