I had 3 out of 11 SB70LC modules which could not be located when using NB Autoupdate or IPSetup. When I connect these 3 modules via the serial port to Mitty I can access the monitor and check settings, change the IP and Mask, reset, etc. But when I try to connect via the ethernet port using the above programs, it still does not find them. I know the base board is good because the other 8 modules worked fine. Any thoughts? Maybe defective ethernet ports on the modules?
Thanks. Jon.
