System Files Bug
talexander
System Files Bug
Post by talexander »
I ran into an issue when referring to ucosmcfc.h, getting C++ linkage errors when referring to it from C files. ucosmcfc.c is used by both C and C++ files and the variable critical_count is defined as an extern, without any previous extern "C" definition. The system files build ok, but referring to ucosmcfc from any new C file in the project will fail.
I suggest changing ucosmcfc.h in future releases so that
#ifdef __cplusplus
extern "C"
#endif
is placed at the begining of the file.
lgitlitz
Re: System Files Bug
Post by lgitlitz »
There is already an extern "c" in this header but for some reason this variable was not in the scope. I fixed this for the release, thanks for pointing it out.
-Larry
Just out of curiosity, why not name all the files you create as .cpp instead of .c? That way you can always use any C++ calls without problems. If you don't want to use C++, just code in straight C, but still name the file .cpp to take advantage of additional type checking.
talexander
I'm doing a lot of work with a pre-existing codebase that is also used for non-netburner systems. So, I do use cpp extensions where I can with new files, but it's not always possible.
