float type
GreenE
float type
Post by GreenE »
Hi Guys,
I need to use floats in my calculations. Does NB Eclipse recognize float? Do we have a math library file available here?
thanks
Re: float type
Yes NB supports float
float somevar; // 4bytes I believe in the current implementation
double someOthervar; //8 bytes in the current implementation
If you want math routines
#include <math.h>
The standard c library routines are there.
Re: float type
Hi GreenE,
Had you tried to multiply floats and it did not work correctly? Just wondering why you had suspected floating point was not supported.
