Am I missing something or is there no document which describes the pins coming off the module. The document MOD5234.pdf under \docs\platform has a table but no decsriptions, similar to the MOD5234 PinIO Class App note.
Am I to refer to Freescale documentation for this kind of info?
Thanks in advance,
Frank
Newbie - MOD5234
Re: Newbie - MOD5234
Frank,
The product page on the module has lots of docs, including a datasheet with pinouts.
http://www.netburner.com/products/core_ ... d5234.html
See:
C:\Nburn\docs\platform\Mod5234.pdf -- pages 9 and 10 list J1, J2 pinout
C:\Nburn\MOD5234\include\pinconstant.h -- lists most of the config options for each pin
More generally, don't miss:
C:\Nburn\docs\DocumentationOverview
C:\C:\Nburn\docs\NetworkProgrammersGuide\NNDKprogMan.pdf
Thanks for the inputs, most of the documentation sited contains lists and tables without descriptions, so what I did was I compared the pins made available on the MOD5234 with the MCF5234 datasheet and hopefully their usage is described there.
(I'm new to Coldfire in general)
Frank
Frank
Hi Frank,
The pin/signal descriptions can be involved. I would look at the NetBurner datasheet, note the signal name, then look it up in the Freescale MCF5234/35 Manual (in your \nburn\docs\manual directory). The signal names should be the same, or very similar.
