The cost (in memory) of type safety
I'm always advocating the use of C++ for type saftety, often recommending the <iostream> library. I knew there was a memory (flash and RAM) cost to this but my main platform is the 5272 and I've never run out of resources. Nonetheless, I was curious as to what the actual costs were, so I ran some tests (and need to run some more) but I blogged up the results and was somewhat surprised at what a heavyweight <iostream> is. I thought others might be interested in the results. If you don't want to bother with the full data the summary is: <iostream> will cost you 6.79% of your flash and 3.47% or your RAM on a 5272.
(As an afterthought for those that don't go to the results, it's misleading to single out <iostream> once <iostream> was brought in it seems a lot of the C++ library is brought in. As other libraries like <sstream> and <vector> were used, the memory hits were relatively small. Just bringing in <sstream> looks the same as just brining in <iostream>.)
Re: The cost (in memory) of type safety
Also note that I believe these require exception handling and this requires run time type identification.
RTTI, is a really big hit.
I really like C++, I use it a lot, but I rarely use the standard C++ template or I/O libraries, as I fnd them to be too bloated for
good code.
Fundamentally if you remove all the extra "Stuff" that is in the c++ standard library streams could be small
and useful.
My "would like to do someday list" has a light weight streams library on the list and a set of nice C++ wrappers for the RTOS features.
barttech
Post by barttech »
As you probably expected, and as I've been warned before, you can't do anything useful with iostream on the MOD5213. By simply including it in my current project, I went from 32% of flash to a 150K overflow.
Paul,
Just so you know I did not clear the misc. setting for NoRTTI handling. It could be I'm paying most of the cost for it anyway. For the tests without exceptions I had the No exceptions handling checked, but when i added the exception testing I unchecked it.
I also wonder about Templates, they get a bad rep for code bloat but whenever I've used them I haven't seen much RAM or Flash increase (assuming I'm using the C++ lib already) and they can be really really convenient and make for easier maintenance of code. Everything I read says the STL and C++ libraries are extremely efficient and should be used whenever possible. Of course most literature assumes you aren't in a limited memory environment.
It would be nice to have lightweight output streams it it meant we could use those features on chips like the 5213, but I'd vote for RTOS C++ wrappers first. (and second I'd vote for classes for the SerialPort, TCP etc, even though I already have my own).
