I see that a spread spectrum clock is available on hardware versions 2.3 and later. Is this mode enabled by default? If not, how to enable it?
Jeff
MOD54415 Spread Spectrum
Re: MOD54415 Spread Spectrum
What version of tools are you using?
We're still using 2.7.5
That is from 2015, so it predates the hardware change by quite a bit. We do not have an example of that for the 2.7.x tools, but if you open up a support ticket they can get you something from 2.9.x and some direction with what needs to be modified.
