SDCard maximum storage space
vmetodiev
Post by vmetodiev »
What is the maximum storage size that I can address using the onboard microSD card slot on MOD54415?
At the moment I am testing with an 8GB Card and the f_getfreespace returns the following.
Total Space On Drive: 3644850176
Free Space On Drive: 3644784640
And here is the code snippet that I am using to generate the mentioned output:
		F_SPACE space;
		int ret_space = f_getfreespace( f_getdrive(), &space );
		if ( !ret_space )
			/* Some Info */
			iprintf("\r\nTotal Space On Drive: %lu", space.total);
			iprintf("\r\nFree Space On Drive: %lu", space.free);
Regards,
Varban
Re: SDCard maximum storage space
Your not using the function correctly to read the high bits. Take a look at the EFFS docs for that function call.
joepasquariello
Post by joepasquariello »
Varban, for cards > 4GB, you need to compute 64-bit (long long) values by combining the "low" and "high" 32-bit fields of F_SPACE. See the code in nburn\examples\MOD5441X\EFFS-MULTIPLE-MMC. Note "%llu" is the format to print long long unsigned.
Joe
F_SPACE space;
volatile int rv = f_getfreespace( drv, &space );
if ( rv == F_NO_ERROR ) {
long long total = ((long long)space.total_high << 32) + space.total;
long long free = ((long long)space.free_high << 32) + space.free;
long long used = ((long long)space.used_high << 32) + space.used;
long long bad = ((long long)space.bad_high << 32) + space.bad;
iprintf( "%llu total, %llu free, %llu used, %llu bad\r\n", total, free, used, bad );
vmetodiev
Post by vmetodiev »
@rnixon
@joepasquariello
Oh, okay... Thank you very much for your suggestions!
Regards,
Varban
