On the NetBurner carrier board (MOD-DEV100) I want to use Serial Port 1 (J8) to communicate with my touchscreen. When I turn on rts for transmit, that is:
SerialEnableHwTxFlow(m_portNumberToUse, enable);
SerialEnableHwRxFlow(m_portNumberToUse, disable);
SerialPort::Handshake = Handshake.RequestToSend
it works fine. I can tell the cable from the touch screen has pins 2,3,5,7 and 8 connected which corresponds to the pins on the MOD100 schematic. I have to use a Null Modem adapter on J8. What do I do to get RTS/CTS to work?
I did notice on two of the schematics R1p08 and R1p09 that it appears I need to put a jumper on JP10 for CTS. I don't see anything for RTS - does it go to another page somewhere? R1p12 doesn't show this header. What is the difference among all the r1pxx versions? I would assume only one goes with my board (a rev V1.04).
Tod
