eTPU, UART and Debugger
Posted: Wed Sep 29, 2010 4:11 pm
by ben-z.lawrence
I apologize if this is in a forum somewhere - I did a search with no results.
In UserMain, using the following code.
EnableTaskMonitor();
// InitializeNetworkGDB();
eTPUInit();
m_diagFd = eTPUFDUartOpen(4,3,MDCP_BAUDRATE, // 115200
MDCP_DATABITS, // 8
MDCP_PARITY, // no parity
FS_ETPU_PRIORITY_MIDDLE);
When compiled, I/O to the specified UART works as expected. If the 'InitializeNetworkGDB' (or the associated _and_Wait) is uncommented, the debugger works, but the UART does not function (no I/O).
We are a bit puzzled as to the reason and was wondering if there was a solution (except for using lots of iprintf's for debugging).
Re: eTPU, UART and Debugger
Posted: Wed Sep 29, 2010 6:21 pm
by ben-z.lawrence
Just read my earlier post and forgot to mention - it is a MOD5234. We have an RS-422 driver connected to the associated eTPU pins and it works just fine unless debugging is enabled - then no I/O. It is really difficult to debug the interface protocols and the flash file system configuration file parsing and such with just iprintf statements :roll:
Posted: Thu Sep 30, 2010 12:11 am
by v8dave
Hi Ben,
Try this. I am using the eTPU UART's and I had an issue with the debugger not running but never saw your issue as I am using them with debug enabled.
Insert an OSTimeDly(); just after the InitializeNetworkGDB(); and see if this fixes the issue.
OSTimeDly(1);
Without this delay I can not debug the main task. It could be related to your issue too. Worth a quick try and see.
Posted: Thu Sep 30, 2010 10:53 am
by ben-z.lawrence
Thanks for the suggestion, I tried it but it didn't work...the debugger works just fine. However, the I/O on the eTPU UART simply appears dead. If I comment out the InitializeNetworkGDB, the eTPU UART works, but, of course, the debugger doesn't work. At a loss as to why the two should have any relation to each other. It seems really strange. We have a TDMA radio using RS-422 connected to the UART and have the TDMA configuration as a file in a flash file system. Trying to debug the details of the radio configuration parser and handling is quite difficult.
Posted: Thu Sep 30, 2010 12:48 pm
Sounds like something in the debugging setup is still stuck on the serial port. The fact that debugging works over TCP argues against that, but it's worth a quick trip to the configuration debug area just to make sure. Maybe try changing some settings and then changing them back?
