ResponseRedirect
Posted: Thu Aug 19, 2010 6:28 pm
Folk:
I'm sure someone has solved this. How can you redirect a user using a functioncall, but without a post function? Whenever I run this code I don't get a redirect, I just see the header output. I use this all the time on asp/php server side scripting. I'm trying to demonstrate this on a SBL2e.
for example, if on a page there is a functioncall:
to the function
The output on a browser is:
HTTP/1.0 302 Redirection Location: index.htm
(followed by whatever else was in the HTML)
Again, this works fine in a post function. But, how can you force a redirect without using a post? Thanks in advance.
<!--FUNCTIONCALL gotonewpage() -->
void gotonewpage(int sock, PCSTR url){
RedirectResponse(sock,"index.htm");
