Rebuilding the system with new eTPU functions
Posted: Sun May 02, 2010 1:01 am
Hi all,
I have worked out that the Quadrature is not actually built into my standard setup so I have used the code generator on the Freescale website to create an eTPU configuration that matches my setup. I have copied the neccessary files to the eTPU directory, making sure I add any Netburner code that is needed (compared to the old files)
I then did a rebuild all system files command from the NBEclipse menu option and the main NB library(MOD5234.a and DBMOD5234.a) shows a rebuild as the date has changed.
I still can't get Quadrature to work even though I have done the above!
Anyone successfully for QD to work?
Cheers,
Cheers,
