Basic Debugger Issue I can not get debugger to launch.
bturner5791
Post by bturner5791 »
I follow the NetBurner Eclipse IDE Getting Started Guide and when I get to Step 8.5 launch the debugger I get the following error.
Error creating session: Target is not responding (timed out)
I think it must be a setup issue but I can not find the issue.
:x
I
main.cpp
(620 Bytes) Downloaded 327 times
error app wizzard.doc
(228 KiB) Downloaded 316 times
Re: Basic Debugger Issue I can not get debugger to launch.
A couple of things to check:
1. Make sure you have the connection setting in eclipse right for the DEBUG build, which are different than the RELEASE build.
2. I have had a message saying the target refused the connection, but never that the target is not responding. If its not responding that would indicate when the debugger tried to connect, a timeout occurred rather than a refusal. So it really sounds like the IP address might be incorrect in your eclipse settings. Or, maybe the app you have downloaded is not running?
