The latest (beta) release for the tools is now available to download from http://support.netburner.com
Changes in 2.4 RC2:
New in Release 24 RC2
* CAN
o Added method to send RTR (CanSentRTR)
* EFFS
o Support for Compact Flash cards up to 128GB
* MAIL
o Added date/time stamps to outgoing email messages
* NETBIOS
o Added NETBIOS nameing and example program
* SB700EX
o Added support for new platform
* SBL2e
* STDIO
o Added function to return current FD mapped to stdio (int CurrentStdioFD( int stdio_fd ))
* TCP
o Added keep-alive functionality and example
o Added extra parameter to Connect() function allowing specification of interface
* uC/OS
o Added post to front of queue & example (OSQPostFirst)
* WIFI IEEE802.11b/g Network Interface Controller (NIC)
o WIFIUG-200CR (RealTek RTL8711 Wireless LAN NIC) released.
o Added WIFIUG_200CR driver and support (rtl8711Library)
o Added progress routine callback to support managing connection changes.
Updated in Release 24 RC2
* Examples
o CB34EX-SerialToEthernet - Added LED feedback
o TestDHCP - Added state debugging messages
o Multicast - Improved feedback messages
o EFFS STD - new example for standard flash file system
o UDP - Added Simple UDP to Serial example
* Mail
o Added SSL mail support & example (Requires Embedded SSL & SSH Security Suite license)
* Real Time Clock (RTC)
o Applies to hardware platforms that support a real-time clock. Added alarm and timer functions. Both of these functions use external IRQ 1
* SSL
o Increased key size to 4096. Large key size affects performance
o Client authentication
* Tools
o Silent installation of USB driver for MOD-DEV-100(70), driver is digitally signed
* WIFI
o Removed WIFI_100CR driver (NetGear MA 701, Intersil PRISM) available through support
o Removed NXP BGW211g driver
o Added parameters to Wifi interfaces to support future devices
Corrections in Release 24 RC2
* ARP
o Fixed possible race condition in which an ARP entry could be aged out while being used
* Debug
o Fixed debug warm reboot bug with Micrel PHY
* DHCP
o Fixed problem with rebind, in which it was possible a DHCP rebind request would not request the previously assigned IP
* EFFS
o Fixed size reporting with large SD cards
* Ethernet
o Corrected PHY latching on soft reset on Modules with MICREL PHY
* FTP
o Increased FTP Buffers to support up to 256 byte paths and filenames
o Fixed flowcontrol issue with f_read/f_write in FTP example applications
* I2C
o Improved reliability of receving bytes in I2C driver
* HTTP
o Corrected buffer overrun on post of large web pages
o Fixed problem in which HTTP POSTs or GETs would fail if the data was received in more than one packet
* Mail
o SMTP: Corrected error condition in which SendMail() and SendMailEx() would not immediately release the TCP socket if the connection was refused by the SMTP Server
o POP3: Modified function POP3_RetrieveMessage to return error if message is bigger than the given buffer size instead of stalling
* PPP
o Modified PPP LCP NAK and modem initialization to prevent deadlock conditions during multiple attempts to connect. Fixed changing of ACCM before and after LCP negotiation and after LCP negotiation
* Serial
o Corrected hardware (RTS/CTS) and software (XON/XOF) flow control issues
o Merged serial software driver source code for similar platforms
* SSL
o Corrected multiple socket connection data contention
* Tools
o Corrected printf floating point reentrancy data contention
You can download this release now. Just log into http://support.netburner.com and click on "Get Latest Tools"
