MOD5234-200IR connector
Posted: Tue Dec 01, 2009 11:33 pm
does anybody know, how to connect the J3 connector (10pin) to the ethernet jack? Im not sure with those LED outputs. Can I power them (20mA each one LED) directly by the 2.5V voltage output form the MOD5234 (pin 3 and 6)?
How should I connect the LEDs?
1) pin 3 -> resistor -> LED anode -> LED cathode -> pin 9 (resp. pin 10)
2) pin 9 (resp. pin 10) -> resistor -> LED anode -> LED cathode -> ground
3) PWR (e.g. 3.3V) -> resistor -> LED anode -> LED cathode -> pin 9 (resp. pin 10)
Or any total different solution? I wasn't able to decode it from the datasheet...
Thank you very much!
Jan Mrazek
Jan Mrazek
