Yesterday, I created a new NetBurner device project and when I built it I got the above error. I hunted down the library in the project properties dialog and deleted the reference. Today I figured out the reason I got the problem was because I used the wrong option under the New menu when I started the project. If you have the same problem I posted a detail blog about it http://syncor.blogspot.com/2009/11/netb ... brary.html. Mostly so that when I make the same mistake about a year from now I'll have a reference that will save me some time.
-Tod
rtl8711Library.a No Such File or directory
Re: rtl8711Library.a No Such File or directory
I take it back the rtl87Librarry.a is now showing up even when I create the project starting with the NetBurner project step.
OK a quick answer from tech support let me know it's a problem specific to NNDK rel24_rc1_beta01 that I'm using. I updated the blog with the info on the correct way to fix it but it only applies to those using this specific interim release.
