Using DHCP w Fallback
Posted: Wed Nov 08, 2023 10:08 am
by SeeCwriter
I'm using v3.4.0 with a NANO. I would like to use the "DHCP w Fallback" mode. On the ConfigPage I set IPv4 Mode to "DHCP w Fallback", enter a valid IP address in "StaticAddr" , and set "StaticMask" to 255.255.255.0. I reboot and verify the configuration sticks. Then I unplug the ethernet cable and power-cycle. Using a serial port, I query for the IP address, and it returns 0.0.0.0. When I plug Ethernet back in, the module gets a DHCP address.
How is the fallback mode suppose to work?
Re: Using DHCP w Fallback
Posted: Wed Nov 08, 2023 11:19 am
How long are you waiting for DHCP to fail? DHCP has a timeout period for retries to the server that is not directly related to link. For example, a situation could be that the Ethernet connection is through a managed switch which takes some time, or some other mechanism that where a link is not immediately available due to outside functionality.
Posted: Wed Nov 08, 2023 12:47 pm
by SeeCwriter
My module has been running for a couple of hours. Still no IP address.
I use the following statement to get the IP address:
IPADDR4 ipa = ifBlock->ip4.cur_addr;
I convert ipa to an ascii string and send it.
Posted: Thu Nov 09, 2023 12:46 pm
If there is never a link it will never timeout.
Having an IP address without having any kind of connection to do something with it is kinda pointless
Until it has link long enough for DHCP to timeout it won't ever have an address...
Try plugging it into a ethernet switch/hub not plugged into anything else...
(I'll confrim this still works in 3.x when I go home today)
Posted: Mon Nov 13, 2023 11:32 am
DHCP times out after 265 seconds.
This can be changed by adjusting two constants in dhcpc.cpp
DEFAULTRETRY
DEFAULTTIMEOUT
Total timeout is (2^(DEFAULTRETRY+1))*DEFAULTIMEOUT
Timeouts are
DEFAULTTIMEOUT, (4)
2* DEFAULTTIMEOUT (8)
4* DEFAULTTIMEOUT (16)
8* DEFAULTTIMEOUT (32)
16* DEFAULTTIMEOUT (64)
32* DEFAULTTIMEOUT (128)
For 252 seconds After DHCP starts cumulative.
(seemed to always be ~265 in my test case, not sure where the missing 13 seconds are)
In future releases these constants will be moved to constants.h where they belong.
If you want a version of constants.h and dhcpc.cpp that have this change, submit a support request.
Posted: Mon Nov 13, 2023 11:33 am
The final 128 second timeout is not compliant with the DHCP RFC (RFC says 64 sec max timeout) , so that was fixed in the new version as well.
Posted: Mon Nov 13, 2023 12:53 pm
by SeeCwriter
Once connected to a network, the fallback works. It falls back in about 4.25 minutes. Close enough for me. Thanks.
