SBL2e Ethernet to 8 TTL OUTPUTS
JoshToolz
Post by JoshToolz »
I need Ethernet to 8 TTL OUTPUTS. I do not need comport. It looks like the SBL2e will do it, if so what would be involved in achieving this? Do I have to burn in custom code? Or can I just send some configuration commands to an ethernet port?
Re: SBL2e Ethernet to 8 TTL OUTPUTS
What electrical specs do you need to meet? Voltage, source/sink current amount?
At what speed do you need to switch the outputs?
The SBL2e can do what you ask without programming at 3.3V. Either through the web server or a tcp connection.
I would recommend checking the manual as well: https://www.netburner.com/download/sbl2 ... rs-manual/
JoshToolz
Post by JoshToolz »
3.3v TTL is fine and they will only change state every few minutes. Thanks for your fast reply.
