Not creating COM port
Posted: Fri Jul 02, 2021 11:07 am
I am not able to see the COM port that VirtualCommPort2.2 is meant to have created in Device Manager, nor can I connect to it with MTTTY.
The NetBurner device I am trying to use is the SBL2e. It shows up on IPSetup, and the settings page is hosted properly.
The problem seems to be with the drivers. I when I run vspdxp_install.exe as admin it apparently does nothing. When I run vbsetup.exe I get windows error 0xe0000235, which may imply the driver is 32 bit and can't run on my 64 bit system.
I tried "right-click, install"ing the INF files, which has not helped.
What can I do to resolve this? Will a different board have more chance of success?
