How do you control echoing of chars with getchar() etc?
barttech
Post by barttech »
My app is echoing every char that getchar() receives. I don't want them to be echoed, how can I avoid this? I've tried ioctl() but can't get it to make any difference. Any sample code would be appreciated. I'm using:
SerialClose( 0 ); // close UART 0
fdSerial = OpenSerial( 0, 115200, 1, 8, eParityNone );
ReplaceStdio( 0, fdSerial ); // stdin
ReplaceStdio( 1, fdSerial ); // stdout
ReplaceStdio( 2, fdSerial ); // stderr
I've tried:
ioctl(fdSerial,8); //IOCTL_RX_ECHO (8) When set echo chars received to tx
Of ioctl() the manual says: "The ioctl command consists of IOCTL_SET or IOCTL_CLR and the bit of the associated options. "
but I don't know how to use IOCTL_SET or IOCTL_CLR.
Sam
Re: How do you control echoing of chars with getchar() etc?
How about using read() instead?
barttech
Post by barttech »
read() echoes too. I don't think getchar() echoed until I tried using ioctl() to control LF and CR being appended to output. Could ioctl() have changed something?
I think something is going on with your app or the serial terminal you are using. read() should not echo, it just fills the buffer you pass as a parameter.
ahbushnell
Post by ahbushnell »
Are you sure your terminal software doesn't have echo turned on?
barttech
Post by barttech »
Neither my terminal program (uCon) nor my application were explicitly echoing. As I expected, the call to gets() was echoing.
This is what I needed to do:
ioctl(2,IOCTL_CLR|IOCTL_RX_ECHO);
Of the second parameter for ioctl, the NetBurnerRuntimeLibraries.pdf says
so I was trying IOCTL_CLR&IOCTL_RX_ECHO, based on the "and". When I looked into ioctl.h I saw my mistake.
Sam
