Are there Help files that can be downloaded for NBEclipse that I can install?
Where is Help?
Where is Help?
Re: Where is Help?
I don't know if this points to the problem, but as I was attempting to see what worked, I received the following popup error message.
An internal error occurred during: "Local Help".
java.lang.NullPointerException
My OS is Win7 32-bit and the installed Java is Version 8 Update 191.
Any suggestions?
Any suggestions?
Re: Where is Help?
I got this error after I updated my 12 year old Eclipse environment form my SB70 SDK. The old one does not work anymore and the updated version doesn't work either. I think it has to do with the nbeclipse*.jar files. Maybe the new Java environment doesn't support that old stuff anymore and producing a java.lang.NullPointerException error.
I think the next option is to use the good old make file construction.
See also viewtopic.php?f=4&t=317&p=12345#p12345
Kind regards, sb70koll
Simplicity is my middle name - Danny Glover - Predator II
