MOD5272 CPU clock speed clarification
ephogy
Post by ephogy »
Hi All,
Just wondering if anyone can clarify the CPU clock frequency on the MOD5272 board.
In the bsp.cpp file, there is a CPU_CLOCK variable defined as
const unsigned long CPU_CLOCK = 66355200
also in the bsp.cpp file, the OS timer is setup as follows:
   sim.timer1.tmr = ( sim.timer1.tmr & 0x00FF ) | 0x0400; // Set prescale to 1/5
sim.timer1.trr = ( WORD ) ( 781250L / TICKS_PER_SECOND ); //Set refernce count to give the proper Timer tick interval
sim.timer1.tmr = ( sim.timer1.tmr & 0xFFF9 ) | 0x0004; // Set Master_Clk/16 and start
Based on this, it looks like the OS thinks the CPU clock is 781250 * 5 * 16 = 62500000
And in the MOD5272 data sheet, it lists the clock speed as 62 MHz.
Does anyone know which one is correct? I'm fairly certain that it's either 62 MHz or 62.5 MHz.
Cheers,
Keith
Re: MOD5272 CPU clock speed clarification
The correct value is 62.5MHz.
ephogy
Post by ephogy »
Much appreciated. Thank you.
