NNDK-2.8.6 - EFFS Not Working
Posted: Tue May 15, 2018 4:49 pm
Using NNDK 2.8.6 with a Mod5270B on a Mod-Dev-70 the file system for the SD card on the Mod-Dev-70 board does not see any files. I checked the SD card and it is fine. In my code I get f_chdrive() returning F_ERR_INVALIDDRIVE. After trying another Mod5270 and then another Mod-Dev-70CR board with the same results, I tried running the EFFS-FTP example in the Examples/StandardStack folder. It gives a traps on a segmentation fault at f_chdir('/'); (line 184) in ftp_f.cpp. It shows the Flash Card Memory usage correctly, but the Display Directory comes up empty.
My code worked fine in NNDK2.8.3. I did a roll back to make sure. I didn't see anything in the notes for NNDK2.8.4, 5 or 6 that looks like you touched the file system.
Can you give me some guidance on this?
Ed
Ed
