Sending enums as messages in a uCos OSQue
barttech
Post by barttech »
The queue examples that I've seen send strings as messages. Can I send integers or enums instead?
I have an enum called 'commands', I'd like to have several tasks send 'commands' to UserMain(). I've tried this:
enum commands{ SETUP_FOV_CMD, SETUP_FOCUS_CMD, SETUP_MIRROR_CMD, SETUP_PADDLE_CMD, ...
A task:
void TouchScreenServer(void*){
iprintf( "Starting TouchScreenServer.\r\n" );
commands TSCommand = NOTHING_CMD;
while (true){
char key = TS.Key();
if (WFOVButton.Hit(key)){
TSCommand = WIDE_CMD;
OSQPost(&CommandQueue, (void *)TSCommand);
} // end of TouchScreenServer
in UserMain :
commands Command = NARROW_CMD;
iprintf("Ready...\n");
while(true){
commands* pc = (commands *)OSQPend(&CommandQueue, 0, &QueueError);
Command = *pc;
iprintf("Working...");
switch (Command) {
// FOV commands follow
case WIDE_CMD :
This will compile, but hangs when the OSQPend unblocks (never prints "Working ..."). The hardware needs a hard reset to respond to the ID after this. I suspect I've gotten my pointers tangled up.
I think I'm missing something fundamental here, does anyone have an example of passing a non-char* message in a uCos OSQue?
Netburner MFC5234. Eclipse
Sam
yevgenit
Re: Sending enums as messages in a uCos OSQue
Post by yevgenit »
The error is mixing enum with pointer to enum.
The sent value is enum:
but the received value is pointer to enum:
Try to replace above line with
commands pc = (commands)OSQPend(&CommandQueue, 0, &QueueError);
________________
barttech wrote:The queue examples that I've seen send strings as messages. Can I send integers or enums instead?
A task:
while (true){
in UserMain :
while(true){
Command = *pc;
switch (Command) {
case WIDE_CMD :
Sam
Yevgeni Tunik
________________________
barttech
Post by barttech »
Thanks yevgenit,
The uCos OS_Q is a queue of void pointers, so OSQPend returns a void pointer,
void * OSQPend( OS_Q * pq, WORD timeout, BYTE * err );
so when I tried your suggestion I get:
error: invalid cast from type 'void*' to type 'commands'
I think where I'm confused is what it is that the queue holds. It holds pointers to "messages", but do these messages always have to be strings? When I "post an enum to the queue", I am really posting it's pointer, I post (void *)TSCommand to the queue. If I try to just put the TSCommand in, I get a compile error, "can't convert type 'commands' to type 'void*'".
So are the queue elements pointers to TSCommand, (or whatever other 'commands' type variable I have placed in the queue)?
How do I get the value of TSCommands that was placed in the queue back out?
The Post/Pend aspect of the queue is working nicely for me, the main task blocks until I post to the queue. If I just make TSCommands global I can access it from any task, but then I only get the current value, there is no queueing of the values.
Thanks?
Sam
yevgenit
Post by yevgenit »
The following tested example shows using message with integer value.
The identical integer representation of both integer and any pointer is assumed.
Such assumption is true for most(?) 32-bit architectures.
______ Start of example____
// Modified example of "NetBurner's uC/OS RTOS Library - 2.18 OSQInit".
#include "predef.h"
#include <autoupdate.h>
#include <smarttrap.h>
#include <taskmon.h>
#include <NetworkDebug.h>
void UserMain(void * pd);
const char * AppName="post_integer";
OS_Q MyQueue;
void task_dst(void*)
BYTE err;
iprintf("Ready to receive messages...\n");
while(true)
void * pData = OSQPend( &MyQueue, 0, &err );
iprintf("Received message: %d\n", (int)pData );
const int NUM_ELEMENTS = 3;
void * MyQueueStorage[NUM_ELEMENTS];
EnableTaskMonitor();
#ifndef _DEBUG
EnableSmartTraps();
#endif
#ifdef _DEBUG
#endif
OSQInit( &MyQueue, MyQueueStorage, NUM_ELEMENTS );
static int count;
OSSimpleTaskCreate( task_dst, MAIN_PRIO+10 );
OSTimeDly(1*TICKS_PER_SECOND);
iprintf( "Starting to send messages.\n" );
while (1)
OSTimeDly(2*TICKS_PER_SECOND);
for( int i=0; i<NUM_ELEMENTS; i++)
iprintf("Sent message: %d\n", count );
OSQPost( &MyQueue, (void *)count );
count++;
______ End of example____
barttech wrote:Thanks yevgenit,
Thanks?
Sam
Yevgeni Tunik
void * is the compiler way of saying I'm reserving a 32 bit block of stuff, I have no idea what you are going to put in there.
So with proper casting any int or enum can be conveted to/from a void *.
enum an_enum {A,B,C};
void * pV;
an_enum x;
x=A;
//Cast to void *
pV=(void *)x;
//Cast back to enum.
x=(an_enum)pV;
barttech
Post by barttech »
Thanks pbreed,
Maybe this a compiler issue. When I try your suggestion, which was what yevgenit said also, I get:
If I first cast to int, then cast to my enum 'commands', it works (ie compiles AND behaves) fine:
int *pc = (int*)OSQPend(&CommandQueue, 0, &QueueError);
Command = (commands)(int)pc;
The error messages I've been getting make it look like the compiler treats enums as pointers, not like the ints I expected.
I think of enums as a subset of ints, so this compiler behavior seems odd to me.
I think this is as clean as I'm going to get it w/o making a Queue for enums myself.
Sam
barttech
Post by barttech »
Thanks yevgenit,
Your example got me over the hump. I'm not sure why, but if I cast to int first, then cast to my enum 'commnds', I get the desired operation from the OSQueue:
Thanks for your comprehensive example!
Sam
