I need to build an appliance that can, in response to a local button press, issue browser url command strings in the format
http://<IP address>/control?cmd=Servo,<Svo#>,<IOpin>,<angle>
. . . .(or equivalent IE: curl) where the intent is to set the angular position of a remote servo handled by another device elsewhere on the network.
A BS2 stamp is at hand and available to handle the button press.
A PINK unit, from several years ago, is at hand and available to handle the network interface.
The one question I don't see an answer to is whether the PINK unit is capable of generating the strings formatted as needed.
Thoughts or advice?
Brian H.
