NNDK 2.5.2
buloup
NNDK 2.5.2
Post by buloup »
I need to improve a dev on CB34EX 100IR with NBEclipse 2.5.2 started in 2012. My support is obviously not available anymore.
Is there a way to download this version of NBEclipse (2.5.2) : I have not found any link in netbruner website.
Thanks a lot,
Frank
Re: NNDK 2.5.2
Renewing your support is only $99 a year....
That gives you access to the latest releases 2.7.6.
Should not be big code changes from 2.5.2 to 2.7.6 unless your using SSL/TLS...
buloup
Re: NNDK 2.5.2
Post by buloup »
Paul,
I know that I can purchase one year support for 99$.
I was just wondering if there was any repository to retrieve this NBEclipse version.
Thanks a lot for your reply
Re: NNDK 2.5.2
Are you on support?
If so ask for 2.5.2, I think you would do better to use 2.6.7
Re: NNDK 2.5.2
Hi Frank,
We do not have a revision that old up for download. You can request through support, or order a CD-ROM at this link:
http://www.netburnerstore.com/embedded_ ... -cdrom.htm
Please specify the version in the comments section of the order.
That said, I would agree with Paul that you should use 2.7.6 instead.
