Hardware reset pin?
FredGuy
Hardware reset pin?
Post by FredGuy »
Does anybody know if the PINK70-100CR has a hardware reset pin on board? I'm having the issue that the communication with the board sometimes freezes and as of now, I just recycle the +5V supply. The more "elegant" solution I prefer is to reset the module from the PIC I'm using.
Fred
Re: Hardware reset pin?
This is an SB70-LC.
Take a look at the data sheet...
Pin 18 is Reset ACTIVE LOW!
The Reset pin IS NOT 5V tolerant.
FredGuy
Post by FredGuy »
Thank you, Paul!
It is actually a PINK70, the 5V (not 3.3V) version. Couldn't find a reset pin for the 5V version. Do you know if the SB70 version has a hardware reset pin?
Fred
